Arnott® Introduces New & Remanufactured O.E. Mercedes-Benz Rear Shocks - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-18-2019, 10:28 AM Thread Starter
Supporting Vendor
Date registered: Mar 2012
Vehicle: Arnott maintians a fleet of over 40 cars for testing
Quoted: 2 Post(s)
Send a message via Skype™ to ArnottDoug
  • • Two new Arnott-engineered rear shocks are available for 2006-2013 Mercedes-Benz® R-Class applications with and without ADS
  • • The company has also released a new remanufactured O.E. rear shock for 2003-2009 Mercedes-Benz E-Class and 2005-2011 CLS-Class applications with ADS and a separate Remanufactured O.E. rear shock for Mercedes-Benz 2013-2018 GL-Class and 2012-2018 ML-Class applications with ADS
  • • Arnott new and remanufactured shocks are backed with a limited lifetime warranty in North America
Arnott, the industry leader in aftermarket replacement air suspension products for Mercedes-Benz®, has introduced new Arnott-engineered rear shocks and new remanufactured rear shocks for various Mercedes-Benz® vehicle applications.New Aftermarket and Arnott Remanufactured Mercedes Rear Shocks from Arnott
SK-3262 is an Arnott remanufactured OE rear shock absorber for the left or right side of the 2006-2013 Mercedes R-Class (W251 Chassis) with ADS and AIRMATIC fitting both vehicles with 4MATIC or rear wheel drive, excluding AMG models.
The two new Arnott-engineered, rear shocks are designed for 2006-2013 Mercedes-Benz R-Class applications with and without ADS (Adaptive Damping System). SK-3217 is for Mercedes-Benz R-Class (W251 chassis) vehicles with ADS excluding AMG models while SK-3218 covers R-Class 4MATIC® and rear wheel drive (RWD) models without AIRMATIC. Both include custom-valved twin tube shock dampers which adapt to the drivers’ style providing an excellent ride.
The thoroughly road-tested shocks are assembled in the U.S. and include new top and bottom mounts, a new polyurethane bump stop and protective dust boot. SK-3217 bypasses the often-problematic ADS system by incorporating a custom-valved shock and includes a coil resister which plugs in to the vehicle’s electrical system to eliminate any suspension dashboard warning lights. Both new R-Class rear shocks require no core deposit and are backed by a limited lifetime warranty in North America.
Arnott has also released SK-3197, an Arnott remanufactured O.E. rear shock absorber with active damping functionality for the left or right side of the 2003-2009 Mercedes-Benz E-Class (W211) and 2005-2011 CLS-Class (W219 chassis) both with ADS. In addition, SK-3268, is an Arnott remanufactured O.E. rear shock absorber with active damping functionality for the left or right side of the 2013-2018 GL/GLS-Class (X166 chassis) and 2012-2018 ML/GLE-Class (W166 chassis) applications with ADS.
Arnott inspects, steam cleans, and spin blasts the O.E. shock to bare metal before it is recharged with new high-performance shock oil. Worn components, such as the piston, rod guides and seal pack are replaced before being repainted with corrosion inhibiting paint. The shock and damping coil are computer tested to assure O.E. performance and active damping functionality. Arnott remanufactures and assembles both shocks (SK-3197 and SK-3268) in the U.S. and backs them with a limited lifetime warranty in North America.
For more information on the company’s extensive line of affordable, high quality air suspension products for more than 20 vehicle makes including Mercedes-Benz as well as motorcycle applications, visit www.arnottindustries.com.
Doug Taylor
Arnott Air Suspension Products
100 Sea Ray Drive
Merritt Island, FL 32953
321-868-3016 X 128 - Direct
800-251-8993 - Toll Free
ArnottDoug is offline
  Mercedes-Benz Forum > Vendor Member Section > Arnott Inc.
