Arnott® Launches Remanufactured Rear Shocks for the 2007-2012 Mercedes-Benz® GL-Class - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-20-2018, 02:13 PM Thread Starter
Supporting Vendor
Date registered: Mar 2012
Vehicle: Arnott maintians a fleet of over 40 cars for testing
Quoted: 2 Post(s)
Send a message via Skype™ to ArnottDoug
Arnott Air Suspension is pleased to introduce SK-3029, an Arnott remanufactured O.E. rear shock absorber for the left or right side of the 2007-2012 Mercedes-Benz GL-Class SUV (X164 Chassis) and 2006-2011 Mercedes-Benz ML-Class SUV (W164 Chassis) with Airmatic and with Adaptive Damping System (ADS) but excluding AMG models.
The shock is inspected, steam cleaned, and spin blasted to bare metal before it is recharged with new high performance shock oil. Worn components, such as the piston and rod guides, as well as, the seal pack are replaced before being repainted with corrosion inhibiting paint. The shock and damping coil are dyno and functionally tested to assure O.E. performance and ADS Functionality. Arnott remanufactures and assembles this shock in the USA and backs it with a Limited Lifetime Warranty.
Features:
* Remanufactured O.E. Shock
* Maintains ADS Functionality
* Recharged with High Performance Shock Oil
* Remanufactured & Assembled in the USA
* Superior Warranty to O.E.
Additional Aftermarket Innovations for the ML-Class and GL-Class:
The featured new aftermarket air suspension strut is a high-quality, cost-effective solution for Mercedes-Benz GL and ML owners concerned about failing O.E. air suspension parts leaving them with expensive and recurring maintenance problems. Arnott also offers new Front (A-2575) and Rear (A-2596) Air Springs and both Arnott Designed New (AS-2792) and Arnott Remanufactured O.E. (AS-2450) front air struts along with a new Arnott Air Suspension Compressor (P-3214) for X164 and W164 Chassis SUVs.
Doug Taylor
Arnott Air Suspension Products
100 Sea Ray Drive
Merritt Island, FL 32953
321-868-3016 X 128 - Direct
800-251-8993 - Toll Free
ArnottDoug is offline
  Mercedes-Benz Forum > Vendor Member Section > Arnott Inc.
