Arnott Introduces New Front Air Struts for the '07-'13 S-Class and CL-Class - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-21-2017, 11:46 AM Thread Starter
Supporting Vendor
Date registered: Mar 2012
Vehicle: Arnott maintians a fleet of over 40 cars for testing
Quoted: 2 Post(s)
Send a message via Skype™ to ArnottDoug
Arnott Air Suspension Products is pleased to introduce the companyís completely new, not remanufactured, Air Struts for the front right and front left side of the 2007-2013 Mercedes-Benz S-Class (W221 Chassis) and CL-Class (W216 Chassis) -- both with AIRMATIC and 4MATIC.
The Arnott struts -- AS-2852 (right) and AS-2853 (left) -- -- feature a new custom-made and tuned twin-tube shock absorber designed to provide a responsive yet comfortable ride. The assemblies are built with a new ContiTech air bladder, new bump stop, new connector, new airline fitting and new heavy-duty crimping rings.
AS-2852 replaces OE Part Numbers:
2213200538
2213200038
2213207413
2213209813
2213201838
2213205213
AS-2853 replaces OE Part Numbers:
2213200438
2213205313
2213201738
221320173880
221320043880
Excellent Alternative
Arnott-designed new struts are an excellent alternative for aging air suspension systems because they provide the luxury, comfort and auto leveling of air springs but replace the aging used stock shock with a completely new custom-valved shock designed to provide a great ride at a more affordable price.
Each Air Strut retails for $749, and each is eligible for a $100 Core Rebate. The new Air Struts are backed by Arnott's renowned Limited Lifetime Warranty.
Arnott recommends replacing both OE front struts at the same time.
Features:
Custom-Designed and Valved New Shock Absorber
Resistor Eliminates AIRMATIC Dashboard Warning Lights
CNC-Machined Aluminum Parts
Pre-Assembled For Easy Installation
Additional Aftermarket Innovations for the Mercedes-Benz
The featured new aftermarket Air Struts for the Mercedes-Benz are high-quality, cost-effective solutions for S-Class and CL-Class owners concerned about failing OE air suspension parts leaving them with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the Mercedes-Benz tradition of quality and performance, Arnott continues to introduce its own products and designs to replace failing original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for the Mercedes-Benz Here.
Doug Taylor
100 Sea Ray Drive
Merritt Island, FL 32953
321-868-3016 X 128 - Direct
800-251-8993 - Toll Free
ArnottDoug is offline
  Mercedes-Benz Forum > Vendor Member Section > Arnott Inc.
