Arnott Introduces New Front Air Strut for '07-'13 S-Class - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-26-2017, 06:19 AM Thread Starter
Supporting Vendor
Date registered: Mar 2012
Vehicle: Arnott maintians a fleet of over 40 cars for testing
Quoted: 2 Post(s)
Send a message via Skype™ to ArnottDoug
Arnott Air Suspension Products is pleased to offer a new, not remanufactured, aftermarket air suspension strut for the front of the 2007-2013 Mercedes-Benz S-Class (W221 Chassis) with AIRMATIC and without 4MATIC.
AS-2820 is designed and assembled in the USA and features a new custom-valved shock absorber assembled with a durable new Continental ContiTech rubber air spring bladder and no lower isolator seal, which is subject to failure on the original equipment.
The strut is partly protected by an aluminum can and dust baffle to keep out debris and is assembled with heavy-duty crimping rings, seals, O-Rings and bumpstop. This fully assembled air strut plugs directly into the OEM connector with no modifcations.
AS-2820 retails for $675 and is backed by Arnott's renowned Limited Lifetime Warranty.
Features:
* New Custom-Valved Shock Absorber
* Multi-Ply ContiTech Air Spring Bladder
* Pre-Assembled for Easy Installation
* Detailed Installation Manual
* Designed & Assembled in the USA
Doug Taylor
100 Sea Ray Drive
Merritt Island, FL 32953
321-868-3016 X 128 - Direct
800-251-8993 - Toll Free
ArnottDoug is offline
  Mercedes-Benz Forum > Vendor Member Section > Arnott Inc.
