LUG NUTS OR LUG BOLTS - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-15-2010, 04:49 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1987 560 SEL
Trading in my 2010 GLK factory 20" wheels for a chrome set of the same. I don't know whether I need to be looking for chrome lug nuts or chrome lug bolts. Where should I look to find a set at a reasonable price? Also, has anyone tried the chrome caps and if so any suggestions where to buy?
Thanks for any help.
bmbenear is offline
post #2 of 5 (permalink) Old 10-16-2010, 05:06 PM
allanX204's Avatar
Date registered: May 2010
Nuts vs Bolts
Many people head to hardware stores searching for particular nuts or bolts without actually knowing exactly what they need. In cases like this, it is important to understand the differences that tend to cause confusion between these hardware parts, especially the like of nuts, bolts and screws.
A nut can be given a simple definition as a small metallic object, shaped in a way as to allow for easy and firm grip, with a spiral cut groove that runs around a hole in its centre. The spiral groove is referred to as the thread.
A bolt on the other hand is a metallic piece with a round stem as its body and threaded into one end, with a head to provide firm gripping at the other end. Bolts form the key part of a threaded connection. Some types of bolts are threaded for the full length and others are threaded for just a small length of the end.
One key difference between bolts and nuts is that bolts come in various length and sizes. The choice of bolt depends on the thickness of the material between the bolt’s head and the nut. However, there’s no particular type of metal that is used to make nuts or bolts. The most common metal used, though, is carbon steel, often coated with zinc to prevent corrosion. Notably, bolts made from stainless steel, a high grade steel material with a large percentage of nickel or chrome, are used in corrosive atmospheres. Other materials that can be used to make bolts and nuts include aluminum, plastic, brass and just steel. Selecting the type of nut and bolt to use depends on a number of factors including environment and strength.
Both nuts and bolts come in many types. Nuts come in the form of hex, cap, coupler, wing, turnbuckle and lock types. The hex nuts are six-sided and a standard spanner is used to turn them. Coupler nuts have some similarity with hex nuts except for their bigger thickness. Like their name suggests, coupler nuts are used to connect two bolts together.
As for bolts, there are the hex type, square, round and flat head bolts, studs and threaded rods both of which have no heads, anchor bolts nor toggle bolts.
Summary
A nut is a small metallic piece of metal with a spiral cut groove that runs around a hole in its centre while a bolt is a metallic piece with a round stem as its body and threaded into one end.
Bolts have different length sizes while nuts have a standard size.
source:
http://www.differencebetween.net/obj...uts-and-bolts/
http://customwheelsmarket.com/lugboltkit.html
http://www.amazon.com/Mercedes-Benz-chrome-lug-bolts-extended/dp/B003O4LCP6
http://www.thefind.com/cars/info-mer...rome-lug-bolts
allanX204 is offline
post #3 of 5 (permalink) Old 10-16-2010, 05:44 PM Thread Starter
WOW!
bmbenear is offline
post #4 of 5 (permalink) Old 10-17-2010, 03:57 PM
Glkka2H's Avatar
Vehicle: 2010 GLK 220CDI BlueEFFICIENCY 4M
Originally Posted by allanX204 View Post
Nuts vs Bolts
A screw, The correct definition of bolt and screw according to Bolt versus Screw Definition:
"Bolts are defined as headed fasteners having external threads that meet an exacting, uniform bolt thread specification (such as M, MJ, UN, UNR, and UNJ) such that they can accept a nontapered nut. Screws are defined as headed, externally-threaded fasteners that do not meet the above definition of bolts."
And threads, a study by themselves: Screw thread - Wikipedia, the free encyclopedia
Then I associated your elaboration with the Standard Reduction Potentials, recently having changed to winter tyres, and again noticing the rust/corrosion on the Hub Chamfer of the Brake Rotor. Aluminum (wheel) on negative volt side, iron on positive -, chrome in the middle etc. And of course is the salt solution (Na way down on the negative side) liberally sprayed on the roads not slowing down the process.
I don't recall this happened so fast in the old days with steel wheels, but then we had real winter road conditions - and no salt.
Glkka2H is offline
post #5 of 5 (permalink) Old 11-07-2010, 11:28 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
The REAL problem is that he's fitting CHROME wheels which are specifically banned by Mercedes, since they're a safety hazard because they often fail to hold air.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X204 GLK-Class
    NUTZ!! Nuts Snapped Off Lug Bolts. xlimodriver W210 E-Class 49 04-09-2013 03:19 PM
    LUG NUTS!! Adullessence The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 08-30-2008 09:24 PM
    Chrome W126 Lug Bolts & Lock Bolts - New/Long/Unused MBL87560SEC For Sale/Wanted/Trade/Giveaway 3 04-05-2006 10:42 AM
    Looking for lug bolts/ lug screws for ml 320 harmin5288 For Sale/Wanted/Trade/Giveaway 1 01-03-2006 02:28 AM
    Lug bolts, lug nuts. Pros and cons. cvayala R170 SLK-Class 1 07-11-2004 04:15 PM
