Funny whirling sound on my GLK 350 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-26-2010, 10:23 AM Thread Starter
Date registered: Jul 2010
Post Funny whirling sound on my GLK 350
I was sitting reading the instruction book in my GLK, with the key off (push start) and it's was very quite and I hear a small whirling noise for maybe 15-20 seconds. Then it does it again in maybe one minute, it always does that, I have the key fob in my pocket. It almost sound like a little pump or something, I am sure it's normal, but just curious what it is, and would it eventually run the battery down? I love my GLK, and I am very impressed with the ride.
waynecarsen is offline
post #2 of 8 (permalink) Old 08-27-2010, 04:06 AM
Glkka2H's Avatar
Date registered: May 2010
Vehicle: 2010 GLK 220CDI BlueEFFICIENCY 4M
Originally Posted by waynecarsen View Post
- it's was very quite and I hear a small whirling noise for maybe 15-20 seconds. Then it does it again in maybe one minute, it always does that, I have the key fob in my pocket.
We have noted the "noise", which is not unlike the sound of the spinning CD, a part of the NAV-system in our last car. When the NAV CD was not inserted, the system did search for it at - intervals.
I don't know for sure what is the origin of "noise", in the GLK, however does unlocking the vehicle start the "preflight" (preparations) of it. A part of these are making the Audio, whichever system is installed, available for use. There is a controller incorporated in the system, so maybe the "noise" is a fan or a laser seeking for a CD etc.
- and would it eventually run the battery down?
Not this electrical-/electronic circuit alone, as this particular circuit most likely is not active when the car is locked, which could be confirmed by locking it while sitting in it. NOTE: The Anti-theft alarm systems on the European market have an Interior motion sensor which can be deactivated by a switch, before arming the alarm.
However, together with all the other (small) sources of battery surge / "drainage" at standstill, its internal surge included, it reduces its capacity over time, given the ride is not frequently "taken on a spin". Faster during cold(er) environmentals, which is the reason why we have an integrated battery charger to "refresh" the battery from time to time. That is good practice for its longevity as well.
Glkka2H is offline
post #3 of 8 (permalink) Old 08-27-2010, 06:54 AM Thread Starter
I do not have the Nav system, thanks for your Ideas and answers. I will try locking the car and see if it stops.
post #4 of 8 (permalink) Old 09-04-2010, 09:37 PM Thread Starter
UP Date, I sat in the car with doors locked, key in my pocket (push button start).
I still hear that very light whirling sound. Sure is weird.
post #5 of 8 (permalink) Old 09-05-2010, 09:45 AM
Glkka2H's Avatar
Hmmm, then we are noticing different whirling sounds. Based on your feedback did I now enter our GLK, locked the doors, i.e. armed the Anti-theft alarm (ATA) by the key, and "our" sound silenced immediately. The sound came back instantly when the ATA was disarmed.
Sorry that it didn't help.
Glkka2H is offline
post #6 of 8 (permalink) Old 01-04-2011, 08:34 PM
Date registered: Jan 2011
Vehicle: GLK3504M
I noticed the same thing - it comes from the fans circulating air, not the CD since I don't have the NAV system.
Mercedes DIII is offline
post #7 of 8 (permalink) Old 01-05-2011, 12:01 PM
Vehicle: GLK3504M
I think it is a cooling fan for the electronics.
Sitting in the vehicle with everything off it will come on every 15 sec or so.
If you turn the ignition on it will run constantly, with the engine running you can't hear it.
If you have everything off and lock the car with the key fob while sitting inside, the noise stops, so now it does not drain the battery. Locking it with the door lock button from inside does not do this.
post #8 of 8 (permalink) Old 11-05-2013, 04:05 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 10 Post(s)
I discovered this same problem, er... feature. I was monitoring the battery voltage to see if the starter battery was getting old - at just over 2 years use no less. I charged it up and it read 12.76 v. A little low but not terrible. I would prefer over 12.85. It sat overnight and I ran around the next day. I read the battery again and it's more like 12.5. This is a problem. I put the charger back on it but now I take the HVAC ductwork off the battery to to take a look at it and I find myself staring at a little squirrel cage fan running like mad.
What the h*** is this? I go inside, turn on the key and kill the climate control - fan still running.
If this fan stops when the car is locked - and I've not verified that it does, this could be a significant drain and a source of my battery drain problems.
When I went to charge the battery the other day it was down at 12.26 - below 1/2 charge and a real problem...
It's not a hot day at around 70 degrees F. Why would the electronics need this?
Any experts on the forum that can enlighten on this?
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Too much of anything is bad, but too much of good scotch is barely enough."
(Mark Twain)
mjhawkins2346 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X204 GLK-Class
glk 350 help craze012002 Audio & Telematics Forum 8 10-13-2015 08:54 AM
NEW TO YOUR FORUM (GLK 350) tua861 General Mercedes-Benz 6 05-23-2010 06:10 PM
Considering a new 2010 GLK-350 Lend27 General Mercedes-Benz 5 03-06-2010 01:54 PM
GLK 350 US Version vs. EU Mike89 X204 GLK-Class 4 01-31-2010 11:55 PM
Weird whirling and squeeking sound when press gas pedal Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 7 03-16-2007 08:32 AM
