i own a 2002 311 sprinter with a 2.2 turbo diesel .. i am experiencing a problem with power at the top end .. no lights are on but after running a while the powers appears to prop a bit and the engine hardly revs over 3k . stop and turn off and the van goes like a dream again ... checked the turbo vacuum and connections all appears ok .. .. i have a small vac hose running from the bottom of the actuator up the bulkhead and hanging down over the engine with a plastic tubular item with an open end facing the engine .. what is this and what does it do ..also i have found a plug under the fuel canister filter going nowhere .. i believe it was originally connected to some sort of sensor attached to the bottom of the filter but cant find a home for it .. could either of these item cause my running problems .. or any ideas greatly appreciated ..
