» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 10-08-2009, 09:30 AM   #1 (permalink)
Date registered: Oct 2009
1997 Sprinter Seat Swap
Hello to all
Newbie here I'm afraid,asking the stupid questions!
I have a 1997 Sprinter 208D(So the early model)
I need to fit a three point seat belt to the inside passenger seat to replace the lap belt.
I've found a firm to retro fit in London for £280 or I can go the dealer route at £400!
But ...Is it possible to change the bench over with a bench from a newer Sprinter? (with an existing three point belt).
Would it be a like for like swap?
Existing Bench
New Bench
If possible is it easy to do?
Any help appreciated,Cheers Dodders
Dodders is offline   Reply With Quote
Old 10-22-2009, 02:45 PM   #2 (permalink)
Date registered: Jan 2007
Vehicle: sprinter 208 d "frankensprinter"
if the new ones use the same one bolt fixing to the top of frame ( door side half way along under side of cushion 13mm head) it should work but i would look to see what extra reinforced to take the strain was done to the later ones
the box in the bottom pic looks bigger than the one you will have if its like mine with a frame extending it over to the centre dont know what the newer ones have though
when in danger or in doubt run around then scream and shout
bazw is offline   Reply With Quote
EDC Sprinter 1997 lost of power kimmi W901-905 Sprinter 7 06-08-2009 04:20 AM
Sprinter Front Passenger Seat Removal??? pdjennings W901-905 Sprinter 3 03-12-2009 12:07 PM
1997 E320 Engine Swap (No Start) CIG3 W210 E-Class 19 11-29-2008 08:21 AM
sprinter 211 ecu swap? wsm racing W901-905 Sprinter 0 11-18-2008 07:50 PM
Sprinter 412 TD 1997 ECU / Boost question ??!!?? ed_menace W901-905 Sprinter 0 07-12-2005 02:43 PM
