» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 09-22-2009, 10:02 AM   #1 (permalink)
Date registered: Sep 2009
sprinter 311 cdi cutting out
can anyone help me got sprinter 2004 which starts fine every time then will cut out as u drive away with edc light coming on then starts again no edc then same problem changed pressure regulator valve to no avail has anyone got any ideas on this please
mikeyc180 is offline   Reply With Quote
Old 09-22-2009, 12:11 PM   #2 (permalink)
Star automotive solutions's Avatar
Date registered: Mar 2009
Vehicle: Sprinter 316 4x4 & Sprinter 313 4x4
FUEL LEAK
its sounds like the filter is drawing air, cheack all the pipes for bubbles, let me know,the result, ill tell you the fix
Star automotive solutions is offline   Reply With Quote
Old 09-23-2009, 04:11 AM   #3 (permalink)
thanks for replying i have checked fuel pipes and there is a few bubbles going around on tick over.
Old 09-23-2009, 12:07 PM   #4 (permalink)
Angry 616 Sprinter
I have the very same problem the truck runs fine and then suddenly loss of power and the EDC light comes on if I then switch the key on off an ON again it runs fine. I have replaced the control unit had the injectors tested and calibrated changed the hp pump but got it back today and did the same thing. I noticed that when it labours a bit in a high gear just before or as the turbo boosts the the power cut and the EDS comes on. I have spent a fortune and the problem does not seem to gao away
Could anyone please help or make suggestions on what I need to check and in what sequence
Thanks
riefra is offline   Reply With Quote
Old 09-24-2009, 02:30 PM   #5 (permalink)
solution
OK Im not at the vehicle so stay with me. on top of the filter is a black bi valve with in let and out let, remove the valve and check to see if it looks perfect onr not, lubricat the seal with lubricant and slowly twisting back and forth ,repalce the valve,( what happens is the seal moves when you put the valve on, and when removed it appears to be ok) bleed the system and start the engine and allow to get to normal temp. press the clutch once and rev to max for 1 min, allow to idle and check for air.
another cause is inside the tank the is a tiny mesh filter , over time the bowl fills with dirt and restricts flows, so when the engine trys to pull fuel it cant, so pull air from the easiest souce.
I prsume that a leak test has been carried out on the injectors.
Please let me know how you get on
Old 09-28-2009, 10:00 AM   #6 (permalink)
have done injector tests fine and carried out the filter advice thats not solved it yet going to look at the tank sender unit and and mesh filter next will let u know how it goes. also the edc still keeps bringing up low pressure codes could this mean the high pressure pump?
Old 09-28-2009, 11:14 AM   #7 (permalink)
there should be no bubbles at all in the line, it will throw up rail pressure codesa for a whole host of reasons it is ill advised to suspect the high pressure pump at this stage, , if you remove the pipe form the bi valve on the filter and block it, using a mity vac, on the line form the center of the filter , test for leaks.
alternative put a fresh line into a can of diesel to the filter this will save you taking the tank off
Old 09-28-2009, 12:27 PM   #8 (permalink)
ok thanks for that ill stay on the case of leaks in fuel line, how would U go about bleeding the system of air
Old 09-28-2009, 02:05 PM   #9 (permalink)
cont..... after replacing black bi valve on filter cheers
Old 09-28-2009, 04:52 PM   #10 (permalink)
just been gonig thru all air in fuel faults on the vito forum and i can see now from your comments that theres more orings and valves around the filter to check for leaks before even thinking about pumps etc many thanks for keepin me on this trail
sprinter 311. 2003 daveck New Member Introductions 3 06-11-2009 07:31 PM
Fitting a Mercedes cruise control kit to my 311 CDI Sprinter. wookie_73 W901-905 Sprinter 1 06-04-2009 03:40 PM
Sprinter 311 stolen but how ? ? izan W901-905 Sprinter 2 05-04-2009 09:05 AM
SPRINTER 311 CDI BATTERY DISCHARGE MERCURY3CYL New Member Introductions 0 02-07-2009 09:49 AM
sprinter 311 cdi Chewy2k3 W901-905 Sprinter 0 04-18-2007 05:24 AM
