stil having problems with the starting will start fine off bump start but not off the key plenty power in battery will run over and over but no hint off starting as i said before it is still reving over the 3000 rpm when bump started so it is not in limp mode . any help would be great
cheers
__________________ iluvJESUS_______Blog
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
Most likely it is an ignition switch problem. I am not sure if you use an EIS in W901, as it would be very expensive. The usual ignition should be ok to DIY to replace, but I don't have the workshop manual. I have attached some info for other classes for your reference.
I have just noticed after I have tried to start with key then turn key off there is a noise coming from the dash somewhere like vibrating cracking noise ???
It has started with key 2 times since the problem started . this was within 2 or 3 mins of stopping it. i dont know if this was the reason or it was something else
cheers
Reason: mistake
Sorry, my English is not very good, I don't understand what you mean again. You mean you started the car for 2-3min and it stalled? If yes, the CPS most likely.
