» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 07-08-2009, 10:39 AM   #1 (permalink)
Vehicle: sprinter 312 D (1998)
sprinter 312 rear suspension upgrade
Hello again- its been a while. I got a trailer in the end and that made me legal again so thanks to benzworld for the help. However I'm a bit bored of feeling every bump in the road so I am looking at options for upgrading the suspension. On my 98 MWB ex ambulance I currently have single leaf springs at the rear (rated for 3200kg), so I could:
-get some twin leaf rear springs from a van breakers, rated 3500kg. about £50 each, but hard to find.
-get an aftermarket spring upgrade from midland road springs or someone like that. About £200 a pair, I'm not sure of their rating.
-go the pikey way and buy a pair of used single leaf springs (£30 each), cut the ends off and drill out a hole for the centre pin, and slide them in in under the exisiting springs. will prob need bigger U bolts and clamps to stop them sliding over each other. they won't sit flat but they will touch at the middle and ends and should act like quite a sturdy relief spring.
I'd appreciate any advice on the last option, or other possibilities.
Thanks
felix
kita is offline   Reply With Quote
Old 08-22-2009, 12:31 PM   #2 (permalink)
Date registered: Feb 2008
Vehicle: vito 120 cdi
you can get air suspension, they do air bags that you inflate with a workshop/garage compressor which assist the leaf springs
steel-jaw-sasha is offline   Reply With Quote
Mercedes sprinter 312 tapping and lack of power problem sprint62 W901-905 Sprinter 1 11-19-2009 10:04 PM
V230 rear suspension... upgrade?? Slimwadey V-Class 18 09-06-2009 06:22 PM
sprinter 312 cdi engine rattle EDTREECE V-Class 1 10-08-2008 11:54 AM
Must upgrade rear suspension - help guzzimaster W126 S,SE,SEC,SEL,SD,SDL Class 2 06-18-2006 12:05 PM
How much suspension travel is there on a SLK32 with OEM suspension; front & rear? Beng R170 SLK Class 1 01-23-2002 10:33 PM
