» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 06-19-2009, 02:00 AM   #1 (permalink)
Date registered: Jun 2009
Fault code P1351 ??
Surely someone has encountered fault code 1351 before. (Start of injection control loop faulty) is so please please let me know your solution of idea on it.
dangler8 is offline   Reply With Quote
Old 07-10-2009, 12:17 AM   #2 (permalink)
Date registered: Jul 2009
Have seen this fault only once before. Initially the vehicle would not run. numerous faults in the fuel pump. Fitted a reconditioned fuel pump and this fault appeared. After checking pump time and again and practically changing every part on the van with a donor vehicle I sent the pump back to the reconditioners. I put a piece of plastic inside the end cap to see if they did anything to it and they rang me a said they bench tested it and it was ok and that the problem was elsewhere. I asjed them if the had pulled it apart to check it they said no as there was no need because it tested fine. They told me they would not charge me as a favour. On the pumps return i removed the end cap to find my plastic was gone and new bolts fitted. I refitted the pump and the vehicle ran as good as new. Hope this helps.
bigdog08 is offline   Reply With Quote
Old 07-10-2009, 12:21 PM   #3 (permalink)
Star automotive solutions's Avatar
Date registered: Mar 2009
Vehicle: Sprinter 316 4x4 & Sprinter 313 4x4
[the fault could be inside the ecu, its common
Star automotive solutions is offline   Reply With Quote
Old 11-02-2009, 04:38 AM   #4 (permalink)
Date registered: Oct 2009
i have the same problem ,what is the contrl loop.
bimmerautoservis is offline   Reply With Quote
Fault Code Ron MB W210 E-Class 4 05-12-2009 11:19 AM
Fault Code Steam707 W163 M-Class 4 03-08-2009 04:58 PM
Fault Code help gngrspis R170 SLK Class 1 07-27-2008 04:00 PM
60% fault code bruiserbruce W126 S,SE,SEC,SEL,SD,SDL Class 11 05-25-2007 05:44 AM
Help with Fault Code Please Eiknujzneb W124 E,CE,D,TD Class 9 07-24-2004 08:37 AM
