» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 06-15-2009, 02:29 PM   #1 (permalink)
Date registered: Jun 2009
Question 412D problem
HI all Im a newbee. Ive just replaced the head gasket on my 412D and although its running it seems to be lacking power as if the turbo wasnt working, Fine for running about town but lacks power and acceleration above 40mph. Auto electrician has checked and found fault P1351(Start of injection control loop faulty) Anyone got any ideas ,help or advice.
dangler8 is offline   Reply With Quote
Old 06-15-2009, 05:39 PM   #2 (permalink)
Date registered: May 2008
Maybe a hose
Dunno if this will help but my 311 had a problem once and i thought it was the turbo as it had no power but it turned out that the big hose at the top of the engine had a split in it, once i changed it, it was fine.
May not be your problem but it's worth a look.
Father Ted is offline   Reply With Quote
Old 06-16-2009, 07:48 AM   #3 (permalink)
Thanks Father Ted but not the answer, Im still looking for advice
brake pedal travel 412d pursangmk2 W901-905 Sprinter 2 10-22-2009 02:36 PM
front passanger door problem and lift gate problem..HELP ME!!! stillf1y W163 M-Class 5 12-13-2007 08:36 AM
Key problem - Expert level problem analysis required philthompson W123 E,CE,D,CD,TD,TE Class 2 09-26-2006 08:48 AM
1994 S600 coupe "Vacuum assist pump problem and now a starting problem Bigpauly52 W140 S-Class 18 09-26-2004 01:36 AM
Update on my cold start studdering problem - problem fixed? Douglas-Indianapolis R170 SLK Class 4 04-25-2001 05:28 AM
