» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 05-06-2009, 06:30 PM   #1 (permalink)
Date registered: May 2009
313CDi cut out and won't start!
I have a Sprinter 313cdi and the EDC Light came on suddenly while driving together with the obvious limp mode power loss. I switched off and tried starting again but it would not start. Once home I detected that the fuel shut off solonoid valve did not click when turning on the ignition.
I replaced the fule shut off valve with a brand new one and the engine started straight away, but the EDC Light remained illuminated. The van was still in limp mode but the engine was running fine for a while, then it decided to shut itself off at tickover and now it will not start at all. Any suggestions, have I wasted money buying a new shut off valve? I have now tested the old valve with a 9v Battery and the solonoid is clicking on and off fine. Anybody know what going on.
Thanks Barry
bcol166703@aol.com is offline   Reply With Quote
Old 05-14-2009, 04:49 AM   #2 (permalink)
Hello,
I have now had this problem cured, by a very professional nice man called Bruce Wales of Star automotive solutions. He has the right equipment and expertise to cure any sprinter problem and is a very knowledgeable person. Bruce helps people out on this site and you will see some of his hints and tips by searching the threads. His charges are very reasonable and he is far better than a Mercedes dealer, he is not one of these people who buy a cheap diagnostic kit and set themselves up as an expert, he is an expert.
The problem was with the EDC, the terminals were corroded and had to be cleaned, and this was identified by his proper Mercedes software and his expertise. When cleaning or checking the ECU terminals he informed me that the thin ones easily break off due to corrosion and that means a new ECU and you cannot just buy one from a breakers yard, because of the coding and the link with other onboard ECU's.
I cannot sing the praises of Bruce high enough because he knows what he is doing and does not cause you any unnecessary expense.
Try Bruce in the first instance, I do not think you will go anywhere else.
Barry Coleman
Old 05-15-2009, 04:10 AM   #3 (permalink)
Date registered: Jan 2009
Barry,
as I am a 313CDI owner, thanks for discussing your problem and solution with us.
Peter
PeterInSa is offline   Reply With Quote
Mercedes 300CE 1991, engine has cut out completely, and won’t start. cbrushton W124 E,CE,D,TD Class 8 03-24-2009 02:47 PM
mercedes sprinter 313cdi non start MF494 W901-905 Sprinter 3 02-28-2009 03:14 AM
1989 300SE cut out and won't start ... help please rainham W126 S,SE,SEC,SEL,SD,SDL Class 10 04-04-2008 11:45 PM
My slk 230 cut off and won't start again kevinHK R170 SLK Class 3 12-06-2006 07:14 AM
engine cut-off and reluctant to start GM3 G-Class 4 02-20-2004 01:22 PM
