» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 05-01-2009, 02:56 PM   #1 (permalink)
Date registered: May 2008
trans bolt pattern
anyone know if the trans bolt pattern is the same on a 2.7L sprinter engine as many other mercedes engine such as 300 and so forth. I'm looking to put an older engine in the place of the 2.7 to do away with the ecu and need to know the best engine to go to. Thanks, Lee
ltcbm is offline   Reply With Quote
bolt pattern markwbabcock@yahoo.com The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 02-19-2008 03:06 PM
Bolt pattern... f1crazydriver W126 S,SE,SEC,SEL,SD,SDL Class 10 04-30-2006 08:44 PM
Bolt pattern Robschaef W124 E,CE,D,TD Class 4 05-09-2005 11:39 AM
bolt pattern Guest (MBNZ) W201 190 Class 2 07-27-2002 08:26 PM
Is the bolt pattern the same? hmm.. G-Class 12 07-23-2002 06:13 PM
