» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 03-22-2009, 04:25 AM   #1 (permalink)
Date registered: Mar 2009
Mercedes sprinter 312 tapping and lack of power problem
hello there, i have a mercedes sprinter 312 and recenty put a second hand engine in it. I knew the engine was good because i drove the van the best part of 100 mile home after buying it. After the swap, when the van was quite warm and under load around 65 the lifters start to tap quite loud. I have changed the oil and replaced the lifters. I was thinking the oil pump next but not too sure?? Any suggestions? thanks michael
p.s does anybody know what the oil pressures should be on good running engine on idle and 2000 revs. thanks
sprint62 is offline   Reply With Quote
sprinter 312 cdi engine rattle EDTREECE V-Class 1 10-08-2008 11:54 AM
Tapping power in engine fusebox evillaundry R170 SLK Class 3 09-25-2008 04:30 PM
Big problem with automatic gear box ?. Lack of power. piapia General Mercedes-Benz 0 04-18-2008 10:44 AM
mecedes sprinter fault codes? lack of power!! minis W901-905 Sprinter 1 12-17-2005 12:56 PM
tapping into 12 volt power source (only when the car is started) f-8 W163 M-Class 1 05-06-2005 11:49 AM
