» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 03-12-2009, 11:34 AM   #1 (permalink)
Date registered: Mar 2009
Vehicle: Mercedes 312LH sprinter 1996
How to remove parkbrake cable from hub?
Hi
I tried for some time to remove parkbrake cable from my hub on my 312 sprinter `96. I need to get it out of the center hub, to install new disc covers. Everythings is loose, but i can`t pull the cable out of that little hole, cause end parts on cable is to big. any one know how to seperate that mechanism at the end?
Thanks for any respons, best regards KnCrashalot
kncrash is offline   Reply With Quote
R&R ourter hub seal 404 (pulling hub) coachgeo Unimog 2 02-19-2008 05:49 AM
anyone know how to remove the sunroof cable from the sunroof? glutton4punishment W123 E,CE,D,CD,TD,TE Class 0 08-23-2007 11:23 AM
How hard is it to remove speedo cable from tranny ? hyprr1 W201 190 Class 29 04-02-2007 11:30 PM
replace rear control arms, necessary to remove hub assembly? BenZ190D W201 190 Class 3 08-05-2005 03:36 PM
300TE front axle. Do I have to remove the hub to replace it? Guest (MBNZ) W124 E,CE,D,TD Class 0 08-02-2002 04:55 PM
