» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-25-2009, 08:19 PM   #1 (permalink)
Date registered: Feb 2009
2004 Sprinter Van in limp mode-check engine light showing
Went into limp mode when govenor shut down engine. I replaced mass air sensor and air temperature sensor and it seems to run right but light is still on. How do I get it to go off? Also my radio went off and needs a code to turn it back on.
a1lock is offline   Reply With Quote
Old 02-26-2009, 09:35 PM   #2 (permalink)
How much do you paid for the mass air sensor and air temperature sensor?
I can not find it in my country.
sprintervm is offline   Reply With Quote
Old 02-26-2009, 11:22 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
There is a chance that the light may go off on its own when the computer realizes that the issue no longer exists. Even if the light goes out, the computer stores the codes until you have a scanner hooked up to read and clear them. Under most circumstances, it is necessary for you to have someone clear the codes with a scanner, though.
Whosdis is offline   Reply With Quote
ABS- ESP- Engine light- limp mode after car wash tbrown W211 E-Class 7 01-29-2009 07:50 PM
E320 Check Engine light-Limp Mode? Transmission? jchumba General Mercedes-Benz 5 11-01-2008 06:03 PM
E320 Check Engine light-Limp Mode? Transmission? jchumba W210 E50 AMG, E55 AMG 3 10-25-2008 11:54 AM
E320 Check Engine light-Limp Mode? jchumba New Member Introductions 1 10-25-2008 09:30 AM
Limp Mode 313 CDI Sprinter garrick@internode.on.net W901-905 Sprinter 2 03-25-2008 02:43 PM
