» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-25-2009, 01:59 PM   #1 (permalink)
Date registered: Feb 2009
308d 1997 fuel cut off relay/ valve/dlc
hi to all this is my first post/question and i am hoping that someone can help me in finding the data connector, i checked the floor level hole but not even any wiring for the dlc, but failing this i need to find the immobiliser relay and fuel shut off relay as after fitting new ignition switch not barrel, the van now starts and runs for a few seconds, but then cuts out after it has shut off the fuel so i assume it has immobilised and turned off the fuel, but of course there are no electrical connections on the pump it must be controlling the vaccum setup, and i need to find a way to sort this, so heres hopeing that someone here knows how to help or can let me know where to obtain the wiring diagram as i can use it to isolate the circuit i need
many thanks
trev
trevoravis is offline   Reply With Quote
Old 03-08-2009, 12:37 PM   #2 (permalink)
Date registered: Mar 2009
Hi, I have a 1997 308D and as far as I know it doesn't have a DLC. The fuel stop is vacuum operated, I've always assumed that there is a vacuum connection to the ignition switch. My son has just acquired a 1997 310D which has all the electronics (MAP etc sensors, ECU etc) and the diagnostic socket is above the passenger footwell. Me, I value the simplicity of the 308, I've spent hours on here trying to find answers to his 'limp home mode' problems... good luck, Alan
Alan42 is offline   Reply With Quote
valve adjustment on 308D sprinter merc308D W901-905 Sprinter 1 12-03-2007 06:21 PM
280ge Fuel pump relay and auxilliary valve questions aggarao G-Class 17 06-05-2007 12:47 AM
Installing immobiliser – where to cut into fuel pump relay circuit to immobilise? OliverK5 W124 E,CE,D,TD Class 7 10-03-2006 12:52 PM
Faulty Fuel Cut-off valve Stromberg Carb? TerryN W201 190 Class 0 01-10-2006 10:27 AM
Fuel Cut Off valve TerryN W201 190 Class 3 05-05-2005 04:07 PM
