» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-23-2009, 05:56 PM   #1 (permalink)
Date registered: Feb 2009
Talking CLUTCH PEDAL SWITCH
Dear friends,
I have a question, hope you can help me.
I notice that when I push the clutch pedal the revs do not work over 3,000 rpm, but when I am not using the clutch pedal it work normally.
I am having some problems with my van, somethimes do not rev over 3,000 rpm, but I pushed several times the pedal and it work normally. Not fault codes.
I thought maybe is the clutch pedal switch, is Clogged sometimes.
What do you think?
PD . is a sprinter 313 CDI, 2002, engine 611
sprintervm is offline   Reply With Quote
Old 02-25-2009, 01:01 PM   #2 (permalink)
yes a clutch seitch shouls sort it but only if the revs hold at an exact amount if they fluctuate check the turbo air hoses for small leaks
trevoravis is offline   Reply With Quote
W116 Clutch Pedal coastline W116 S, SE, SEL, SD Class 8 01-21-2009 08:39 AM
Clutch pedal assy. deezer5150 R/C107 SL/SLC Class 1 10-30-2007 08:06 AM
Clutch Pedal Adustment??? Metastable W203 C-Class 3 11-17-2004 10:12 PM
Clutch Pedal problem KGard W124 E,CE,D,TD Class 3 10-12-2004 03:52 PM
Clutch Pedal ShaneO G-Class 1 11-25-2002 01:30 PM
