» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-14-2009, 10:30 AM   #1 (permalink)
Date registered: Feb 2009
Vehicle: 2004 311CDI LWB Sprinter
Steering???
Hi all, new here. I got an 04 311 LWB and the steering has just gone heavy when idling. topped up power steering fluid, but still seems to be happening. Anyone have any ideas? thanks
nouse4anut is offline   Reply With Quote
Old 02-15-2009, 02:13 AM   #2 (permalink)
Date registered: Apr 2005
help
power steering pump leaking ?gone??
i will try to help but it seems from joining the forum no one offers up help so far??
timberdog is offline   Reply With Quote
Old 02-15-2009, 09:54 AM   #3 (permalink)
thanks, it doesn't appear to be leaking. It still works normally when driving along, just when i'm not moving it goes heavy - sometimes its like the engine aint running
Old 02-15-2009, 12:06 PM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
It sounds like the pump is finished.
Whosdis is offline   Reply With Quote
Old 02-15-2009, 01:20 PM   #5 (permalink)
OK thanks, not really the news i was looking for :-( but at least i can maybe get it sorted now
Old 02-22-2009, 12:34 PM   #6 (permalink)
Date registered: Feb 2008
Vehicle: vito 120 cdi
I find the same thing not that much help around!!
I would agree it sounds like the pump is on its way out, does the steering get lighter with a few revs on at standstill?
steel-jaw-sasha is offline   Reply With Quote
Old 02-22-2009, 03:17 PM   #7 (permalink)
When I first start the steering is fine, then after a while the steering is like the engine aint running at standstill but ok when i'm driving along. It is lighter when i give it a few revs at standstill tho, would it still be the pump? Thanks
Old 02-24-2009, 01:21 PM   #8 (permalink)
yes it sounds like it is the pump! you could try changing the oil but I think it needs a new pump.
Old 03-20-2009, 08:39 PM   #9 (permalink)
Date registered: Mar 2009
Vehicle: 1987 300D Turbo (RIP), 1995 E420, 1993 400E
Does the pump have a filter? On the cars, there is a filter down in the resevoir. I replaced one on a used benz I picked up trying to solve a similar problem. The filter was clogged, and the addition of the new filter made the world of difference. It was amazing!
Regards,
Aaron
AaronJW124 is offline   Reply With Quote
'99 ML430 Power steering fluid leak from steering rack boot? XxAndrijanXx187 W163 M-Class 15 10-26-2009 05:54 PM
light steering...steering wheel tugs at speed kelland W163 M-Class 40 10-17-2008 07:13 AM
parametric steering or direct control steering ierax R171 SLK Class 12 07-03-2006 04:56 PM
Does "Direct Control Steering" = Parameter Steering? masmole R171 SLK Class 1 10-21-2004 03:58 AM
Fixing sluggish steering issue / replace steering damper (pics) Rainmaker W140 S-Class 8 09-17-2004 10:51 AM
