» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-12-2009, 02:37 PM   #1 (permalink)
DBTRANSPORT's Avatar
Date registered: Dec 2006
Vehicle: 316cdi
Post Sprinter cdi engine heater booster help
My 316cdi 2002 is fitted with an eberspacher hydronic D5WS heater. Its been fitted from new and heats the engine coolent so as to get hot air in the cab more quickly and to maintain engine temp on very cold days.
My question is has any one else had problems/faults with this heater and where did you go to get it fixed or serviced. As its a MB fitted heater its been programed so as my local Eberspacher agent cant access the electronics and my MB dealer says if it dont work they would replace the heater. As they cost in excess of £900 I dont want to go that route.
Oh should have said the heater fails to do anything when you turn it on, however according to Eberspacher if the heater fails to ignite 3 times in a row it goes into shutdown mode till a repair and reset is carried out.
DBTRANSPORT is offline   Reply With Quote
G 400 cdi (heater booster) Lunde G-Class 14 10-02-2009 12:02 PM
sprinter 312 cdi engine rattle EDTREECE V-Class 1 10-08-2008 11:54 AM
US 270 CDI Conversion Using Sprinter Engine ez rhino G-Class 20 05-27-2008 03:40 PM
heater problem sprinter 311 shaunk W901-905 Sprinter 1 03-25-2008 02:48 PM
heater problem sprinter 311d shaunk W901-905 Sprinter 0 09-02-2007 08:30 AM
