» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 01-27-2009, 02:16 PM   #1 (permalink)
Date registered: Jan 2009
51 plate 311 sprinter wont start!
Hi i have not long had my 311 cdi sprinter on a 51 reg a few times it has taken a long time to start but was investigating a chufing noise and found one of the injectors leaking ran up with top of the inlet manifold off for about one min and the engine cut out and wont start,I have removed the injector and replaced the copper washer and re assembled it put inlet manifold back together but it wont start just turns over no lights up on dash
any ideas??
seems to be fuel up to the injectors under pressure.
Cheers Rob.
sprinterrob is offline   Reply With Quote
Old 01-29-2009, 06:17 AM   #2 (permalink)
Rob, I have exactly the same problem as you except on a 2000 313 cdi. Have you got any ideas yet? We have tried 'easy start' but no luck.....
DaveAlpine is offline   Reply With Quote
Old 03-08-2009, 05:52 AM   #3 (permalink)
Date registered: Mar 2009
Hi, i have the same problem, did you solve this? what was the problem?
Cheers, matt
matt101 is offline   Reply With Quote
Old 03-12-2009, 03:09 PM   #4 (permalink)
well lads, i had to pull the van for more than half mile to get the engine working
minduxirl is offline   Reply With Quote
Old 03-13-2009, 10:20 AM   #5 (permalink)
Star automotive solutions's Avatar
Vehicle: Sprinter 316 4x4 & Sprinter 313 4x4
injector problems
I have many years of experience on these cdi engines, dont start playing with them, there are ways to track the faults, I have many happy customers for whom I have sorted the problems.
1 st the chances of all injectors being faulty are slim to none, its usualy just one, which i can normally diagnose over the phone. forget fault codes they just throw you off the scent. I look forward to hearing from you guy, or type sprinter ecu into ebay and find me there.
Star automotive solutions is offline   Reply With Quote
02 C240 Wont Upshift / Weird Messages / Now Wont Start jondag W203 C-Class 7 12-03-2008 08:15 PM
heater problem sprinter 311 shaunk W901-905 Sprinter 1 03-25-2008 02:48 PM
After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 09:00 AM
sprinter 311 cdi Chewy2k3 W901-905 Sprinter 0 04-18-2007 05:24 AM
311 sprinter start error and others Rob_Grange W901-905 Sprinter 3 12-27-2006 12:27 PM
