Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 09-19-2008, 06:55 PM   #1 (permalink)
Date registered: Sep 2008
316cdi starting problem
my work place owns a 2005 mercedes 316 cdi van, it has this problem with starting sometimes when cold. when the key is turned to start poisson all the dummy lights come on like they should but the a/c fan turns on. and if the fan turns on the van will not start. If the fan comes on, the glow plug light remains on. If I put an electric heater in the cab for some time (depending on ambient temperature) I will turn the key on, after a few seconds the glow plug light goes out and the sprinter starts normally; but after the van sits after a night it will do the same thing. does this make sense to any one. is there some type of sensor for the glow plugs or a/c fan sending the wrong temp to the glow or a/c to cool or ???? When it acts up, I get a P1482, P1610 and P2134 codes.(2 glow plug, 1 engine control relay) I put in a known good engine control relay with no change. any ideas
mcsammons@mac.com is offline   Reply With Quote
316CDI No Instrument light when running mosquito68 W901-905 Sprinter 0 02-21-2008 05:07 PM
1994 S600 coupe "Vacuum assist pump problem and now a starting problem Bigpauly52 W140 S-Class 18 09-26-2004 01:36 AM
Starting Problem (Back window rolls down when starting up the car) fastneutron W202 C36 AMG, C43 AMG 3 08-08-2004 11:23 AM
Starting Problem Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 03-25-2002 08:11 AM
Starting Problem Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 03-29-2001 02:05 AM
