» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 07-17-2008, 07:39 AM   #1 (permalink)
Date registered: Jun 2007
Post clutch replacemant
I have a 2004 mercedes sprinter with sprint shift gearbox.Is there anybody out there that has replaced a clutch.I have heard that when you remove the gearbox that the gears have to be re set by mercedes any information would help.
ben stabler is offline   Reply With Quote
Old 08-13-2008, 06:31 AM   #2 (permalink)
Date registered: Aug 2008
Hi, I haven't personally replaced a clutch yet on the sprintshift transmission but have fixed many other problems and I can tell you that the clutch slipping point and fully opened and closed positions as well as the coefficient of friction will need to be re-learnt by the transmission control unit. The gear positions should not be altered by a clutch replacement. You also need to replace the dual mass flywheel and it would be silly to not replace the center bearing/hydraulic actuator while it's all apart. The clutch settings need to be programmed by the Mercedes Star Diagnosis software/hardware.
Hope this is of help,
Iggyjoe
iggyjoe is offline   Reply With Quote
Replace the compressor clutch alone, or the clutch and compressor... to loss W123 E,CE,D,CD,TD,TE Class 9 06-19-2008 01:59 PM
Replace clutch slave cylinder and bleed clutch jimmyl W123 E,CE,D,CD,TD,TE Class 1 03-08-2008 09:49 PM
clutch bmt808 W203 C-Class 1 01-18-2007 12:29 AM
clutch Kuzuki G-Class 7 01-10-2006 06:25 PM
A/C clutch Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 07-25-2001 08:17 AM
