Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 07-16-2008, 12:15 PM   #1 (permalink)
Date registered: Jul 2008
Sprinter 310D Indicator fault
Hi all,
I've got a 1999 Mercedes Sprinter 310D van with a fault on the indicators (flashers).
When turning left there is a horrible buzzing noise from the left hand relay located under the steering column and the indicators fail to light. Replacing this relay has not solved the problem.
Is there another relay (presumably a flasher relay located somewhere?) that could be causing this?
Many thanks for any help!
Squibby
squibby81 is offline   Reply With Quote
Old 07-17-2008, 01:53 AM   #2 (permalink)
Sorry, should have mentioned that the hazards work fine, showing there's no fault with the wiring to the indicators themselves down that side.
sprinter 313 cdi wierd fault rosin dubh W901-905 Sprinter 7 04-01-2008 08:31 AM
Indicator lights fault leighw General Mercedes-Benz 0 03-24-2008 02:52 PM
2001 Sprinter 316 Cdi Pullaway Assist Warning Light Fault twodogron W901-905 Sprinter 5 01-18-2008 10:42 AM
Fault codes 2000 313CDI Sprinter Mr. T. W901-905 Sprinter 5 12-22-2006 12:25 AM
mecedes sprinter fault codes? lack of power!! minis W901-905 Sprinter 1 12-17-2005 12:56 PM
