hi can you please help
I have a 313 2003reg and I keep getting air in the brakes I have put a new master cylinder on and there is no leaks I can find "looked over it about 20 times” does not lose any fluid when I bleed the brakes I get a ton of air out of rear drivers side takes about 5secounds to reach bleed nipple .when I bleed the brakes the pedal is spot on and then just goes down hill till there is nun left I have dun this 10 times all I can think is air is getting in the abs pump some how
can you please help
I cant seam to find a s/h one with the same code on it and I don’t really wont to buy a new one for £1300
