Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-28-2008, 04:15 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 1997 308D Pickup
Help ! My indicators are doing my head in....
I have a 97 308D with 415k on it, obviously it has a few niggles, but the most annoying is the left hand indicator doing double time. This is due to the wing mounted indicator not working, I have changed the bulb and cleaned up the contacts but to no avail. The right hand one has done this at times as well, but is OK at the moment.Any ideas anyone ?
j4 odds is offline   Reply With Quote
Old 03-01-2008, 02:32 PM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 318CDi Auto
Send a message via Skype™ to radiotwo
Hi j4
It will be down to a bad connection or a broken wire, take off the fitting from the wing, and check the wires behind, if you cannot see a broken wire then check with a volt meter (leave the indicators on !) (if it is a anolog meter, the meter will go up and down) if the power is there at that point, then check out the bulb connection.
if there is no power at that point at all, try putting one of the test leads onto bare metal and either of the connections to the lamp holder, if you still don't have any joy, the last resought is find which is the -ve wire(by using a multimeter on resistance measurment) then running a new wire from the +ve wire of the front indicator fitting
Hope that helps !
Radiotwo
radiotwo is offline   Reply With Quote
Old 03-01-2008, 03:29 PM   #3 (permalink)
Vehicle: vito 120 cdi
have a look behind the head light there is another connector for the side indicator wiring and it is possible that this is corroded, check the wiring in this area also for damage
steel-jaw-sasha is offline   Reply With Quote
Old 03-03-2008, 03:56 PM   #4 (permalink)
Thanks for those tips chaps ! Will give it try tomorrow.....
Old 03-18-2008, 08:56 AM   #5 (permalink)
Date registered: Mar 2008
There are two small grey relays at the bottom of the fuse panel try replacing the indicator one....i've had a few go and they exhibit similar probs,you may want to remove the 'handlebars' [indicator/wiper arm assy] and see if the contacts are dirty....
sprinterman is offline   Reply With Quote
Bit of help with indicators montymole V-Class 4 08-29-2007 11:09 AM
Crystal indicators Bazzle R170 SLK Class 0 12-11-2006 11:46 PM
Indicators!!!! Aaaaargh!!! esther1uk Audio & Telematics Forum 1 08-27-2005 10:38 PM
white indicators banflu W123 E,CE,D,CD,TD,TE Class 33 04-03-2005 03:14 PM
The next dilemma - too many indicators? anthinhk R129 SL Class 1 01-08-2005 12:51 AM
