Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 02-02-2008, 04:45 PM   #1 (permalink)
Date registered: Aug 2006
Glow Plug Horror
I am trying to remove the glow plugs in my '05 Dodge Sprinter. After spraying the front 2 plug wells with WD 40 to try & loosen the threads I was fooled into thing I had unscrewed the glow plug. Wrong. I had just turned the inside stem. then thinking all I needed to do was wiggle the said loose plug, I pulled the centre core out of it. Opps. Now what? Drill it out? I have about 2 threads left sticking out of the head. Any one else had this problem?
b1mmuo27 is offline   Reply With Quote
Old 02-04-2008, 08:10 AM   #2 (permalink)
Date registered: Jan 2008
Best trying easyouts first but get a good set not the cheap ones ?
grimreaper is offline   Reply With Quote
Old 02-04-2008, 05:36 PM   #3 (permalink)
Tried
Thanks but I tried the good easiout & it broke. I used a carbide tip bit to drill the easiout. Not finished that yet. Then I have a reverse drill bit I am going to try.
Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 7 01-28-2008 08:10 PM
DIY Glow plug relay and Glow plugs 240Dbio W123 E,CE,D,CD,TD,TE Class 11 01-16-2008 03:37 PM
Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 09:45 PM
Late Glow glow plug relay smallfence W123 E,CE,D,CD,TD,TE Class 14 07-20-2006 01:40 AM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 05:58 PM
