Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 01-30-2008, 02:24 PM   #1 (permalink)
Date registered: Jan 2008
1986 309D viscous fan removal
Can anyone help on how to remove a viscous fan from a 309D built in 1986. There are no bolts on the front, and I cant see how to remove it from the rear. The fan hub is BEHR. There is a bimetal strip covering a small brass button on the front.
My WIS CD and a printed Russek manual has nothing to offer.
Thanks in advance
RogerM is offline   Reply With Quote
Old 02-18-2008, 05:46 AM   #2 (permalink)
From memory, there should be a 6mm allen bolt in the centre of the fan, best to use an air gun, you really dont want to round off the bolt. One short sharp blast from the air gun normally does it.
rickscott1969 is offline   Reply With Quote
Overheating... viscous fan? bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 4 05-23-2007 02:08 AM
Viscous Fan Coulping bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 3 10-03-2006 07:56 AM
viscous fan questions neil.b W126 S,SE,SEC,SEL,SD,SDL Class 13 07-14-2006 10:14 PM
viscous fan on sel dackdyde General Mercedes-Benz 13 01-18-2006 04:05 AM
Help req viscous fan removal E320 Lynall General Mercedes-Benz 4 09-11-2004 11:25 AM
