Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 01-19-2008, 06:30 AM   #1 (permalink)
Date registered: Jan 2008
316 propshaft
Hi, I have a 2001 316 LWB on which the rear centre bearing has gone damaging the rear section of the 3 piece propshaft.
A new prop from Merc is horrendously expensive!
My question is are the propshafts from the 311, 313 & 316 all the same as they are readily available from breakers but they are all from 311 or 313.
Thanks Colin
3265colin is offline   Reply With Quote
Old 02-27-2008, 03:04 PM   #2 (permalink)
Date registered: Feb 2008
Vehicle: vito 120 cdi
I have interchange the props before with no problems, just make sure it is the same wheel base
steel-jaw-sasha is offline   Reply With Quote
Old 03-10-2008, 04:01 PM   #3 (permalink)
DBTRANSPORT's Avatar
Date registered: Dec 2006
Vehicle: 316cdi
Why not just have the prop repaired, there are companys that specialise in prop shafts. Ask at a local non fransise HGV workshop if they know of one or try the yellow pages.
You dont say where you are from but if you are near Cambridge then try Bailey Morris in Eaton Socon.
DBTRANSPORT is offline   Reply With Quote
316 Automatic - Not sprintshift angelhoper W901-905 Sprinter 1 09-11-2007 05:06 AM
Sprinter 316 CDI performance brake kit borbetchina W901-905 Sprinter 3 03-12-2007 11:10 AM
reverse camera 316 campo W901-905 Sprinter 5 02-07-2007 11:30 AM
Heat! (also propshaft...) LondonThing W124 E,CE,D,TD Class 7 02-07-2005 03:12 PM
propshaft again Merlin G-Class 4 06-23-2004 12:23 PM
