Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 10-28-2007, 06:28 PM   #1 (permalink)
Date registered: Oct 2007
Vehicle: 2007 winnebago VIEW with 06 mercedes engine
fuel filter change
i purchased a new fuel filter for our 07 winnebago view built on a dodge sprinter van chasis with a 2006 mercedes 2.7 ltr engine. i am new to this group and don"t know if I'm in the right forum, but need advice as I am only familar with yanmar and volvo marine diesels using a manual fuel valve and manual pump for bleeding after changing spin on filters. appreciate any help or redirection
james l rust is offline   Reply With Quote
Old 12-03-2007, 06:05 PM   #2 (permalink)
Date registered: Dec 2007
Vehicle: Viano 3.0cdi V6, C 220cdi Coupe
Try to fill the filter up with clean diesel before fitting it as this will give the engine a quick start, it should keep going, if not just crank the engine until it starts, no more than 20 second cranking as the s/motor gets a bit warm.
Gaza32 is offline   Reply With Quote
fuel filter change and no go kiva diesel W126 S,SE,SEC,SEL,SD,SDL Class 7 07-15-2007 01:00 AM
When to change fuel filter Musikmann W210 E-Class 7 07-05-2007 12:57 PM
Fuel Filter Change pdoering W123 E,CE,D,CD,TD,TE Class 6 02-12-2007 04:22 AM
Fuel filter change 1976240D W123 E,CE,D,CD,TD,TE Class 1 01-13-2007 07:35 PM
Fuel filter change bcool R129 SL Class 2 09-12-2004 01:01 PM
