Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 10-19-2007, 11:12 AM   #1 (permalink)
Date registered: Oct 2007
310 Sprinter, Blue Smoke & Misfire
Hi
We have a 310d 5 cylinder sprinter, around a 1998 model.
We were driving back the other night when it developed a slight misfire when driving, it still idles lovely. The revs also appear to be limited by the misfire as we cant rev very high in gear.
In the light we noticed it throwing out lots of blue/white smoke smelling of diesel, oil and water levels appear fine. We dont really know where to look now, we bled the fuel system just incase the slight misfire was something to do with air.
Any ideas or pointers?
Cheers
Rich
16v205 is offline   Reply With Quote
Old 11-08-2007, 03:13 AM   #2 (permalink)
Date registered: Jan 2007
Cylinder head gasket oil leaking in combustion chamber
Benz the best is offline   Reply With Quote
Old 12-03-2007, 06:01 PM   #3 (permalink)
Date registered: Dec 2007
Vehicle: Viano 3.0cdi V6, C 220cdi Coupe
Sounds like the advance in the fuel pump has stuck.
If you remove the oil filler cap and run the engine be ready to catch the oil as it chucks it out fairly quick and a lot of pressure is there (just hold your hand over the oil filler hole it usually shows a blown h/gasket as they normally blow across the front between number 1 and the timing case.
I would say its more the first comment.
Gaza32 is offline   Reply With Quote
Blue Smoke jwratts W210 E-Class 5 07-24-2007 06:20 AM
blue smoke annasdad W210 E-Class 1 11-12-2006 06:34 AM
Blue smoke modulacom W126 S,SE,SEC,SEL,SD,SDL Class 18 02-12-2005 03:57 AM
More on Blue Smoke timberock W126 S,SE,SEC,SEL,SD,SDL Class 2 10-08-2002 05:49 PM
E320 Misfire/Fuel smoke at idle & steady throttle Guest (MBNZ) W124 E,CE,D,TD Class 4 12-20-2001 08:13 AM
