» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 10-03-2007, 09:48 AM   #1 (permalink)
Date registered: Aug 2007
Vehicle: 2006 311 LWB Sprinter Panel Van
311 Air filter cover removal.
I`ve recently bought a 311 (2005) and have so far failed to get the air filter cover off enough to remove and renew the filter. Is there any trick to doing this? I can`t believe it`s not a simple job!
Thanks
Colin
pulhamdown is offline   Reply With Quote
Old 10-11-2007, 01:49 AM   #2 (permalink)
I`ve now discovered that the heat shield for the turbo has to be removed first!
Old 06-21-2008, 12:19 AM   #3 (permalink)
Date registered: May 2008
Vehicle: Mercedes Sprinter 312D
Same with the 312D.
Be careful pulling the cover out as it is easy to poke a hole in the filter.
I blow the filter through with compressed air and it looks as good as new.
Might replace it at 50,000K
Can anyone tell me what the replacement period for these air filters air.
When I bought my Sprinter camper van(225,000K), it had the operators manual
but no technical manual at all.
Lee Australia
ldevries is offline   Reply With Quote
Air filter cover hole on top leojoel W201 190E, D-Class 3 04-05-2007 05:02 PM
2003 c240 air filter cover removal? silver1 W203 C-Class 4 01-31-2007 09:48 AM
Oil on air filter Cover dilanja W126 S,SE,SEC,SEL,SD,SDL Class 9 01-30-2006 05:09 PM
Hole in top of air filter cover supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 10-18-2003 08:03 PM
How do you take off the engine cover to get to the air filter??? Peter-San Francisco R170 SLK Class 0 05-27-2001 04:43 AM
