Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 09-20-2007, 10:20 AM   #1 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
OT: but sexy as hell!!!
sorry for posting here as apposed to off topic, but no one really cares about anything even vaugely automotive related in that section of the forum. i just had to share this pic because i think this thing is stunning. very simple and clean with a perfect stance and wheels.
TUNINGGRüPPE.COM
NüR-SPEC is offline   Reply With Quote
Old 09-20-2007, 10:46 AM   #2 (permalink)
white500se's Avatar
Date registered: Feb 2005
Vehicle: '80 500SE AMG '80 300SD '78 450SLC
Well a tarted up Sprinter is, um, different.
John
'80 500SE Euro '5.0 AMG'- 5.0 AMG engine, Gleason rear diff (still trying to find the ratio) and full aero kit. Stock interior. BBS RS133 8x16 3 piece wheels with Michelin XGT Z4 245/45-16 tires.
'78 450SLC milan brown metallic/bamboo leather
'80 300SD
white500se is offline   Reply With Quote
Old 09-20-2007, 11:04 AM   #3 (permalink)
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
Brabus does mean Sprinters and Vianos too.
My brother is very keen on the Viano.
BRABUS
4.4
Basis:
Viano 3.5
Power enhancement by displacement enlargement 4.4 by use of a special crank shaft and enlarged bore with appropriate pistons. The suction and the outlet section of the cylinder head is flow-optimized and finetuned with two special camshafts according to the displacement. Furthermore larger valves are used. The modification is completed by a back pressure lowering metal-catalytic converter (four monoliths with a full OBD II suitability).
Technical data
Displacement cm2 4338
Bore/stroke mm 99,5 / 93
Compression ratio 11,0 : 1
Torque Nm 430
at min-1 4200
Power output kW/PS 239 / 325
at min-1 5500
Performance:
Acceleration 0-100 km/h s 7,2*
Top speed Vmax: 230 km/h*
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline   Reply With Quote
Old 09-20-2007, 12:38 PM   #4 (permalink)
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560 SEC AMG, 134k (Pearl black/black); 2008 Subaru Outback PZEV, 8,700 (actual) miles.
Send a message via AIM to cascade
Looks like the answer to a question nobody asked
Probably corners like a brick rolling sideways.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity."
Oil Burner Kartel Member #53
cascade is offline   Reply With Quote
Old 09-20-2007, 01:36 PM   #5 (permalink)
JFlyer's Avatar
Date registered: Apr 2006
Vehicle: '91 560 SEC
Send a message via AIM to JFlyer
My question is "Why?"
Is this for fast delivery of perishable goods?
Jay
Gulf Coast Coupes
'91 560SEC w/3pc. AMG wheels, clear corners, no cats
owned a '82 300SD
JFlyer is offline   Reply With Quote
Old 09-20-2007, 01:57 PM   #6 (permalink)
Date registered: Aug 2006
Vehicle: 1980 380 SE (Euro)
holyshit awesome
why build cars? why drive them? why not?
cause we can. ;]
Batou is offline   Reply With Quote
Old 09-20-2007, 02:51 PM   #7 (permalink)
AxelWulff's Avatar
Vehicle: 1990 SEC
Because people confined to wheelchairs want to go fast in style too............
Old 09-20-2007, 03:18 PM   #8 (permalink)
Thorpilot's Avatar
Date registered: Aug 2004
Vehicle: Many different MBZs
I saw one of those in Grand Junction, CO last week at a business that does repair, and custom interiors on private jets.
VERY COOL!!!
Check out this link:
eMercedesBenz - The Unofficial Mercedes-Benz Weblog
Thorpilot is offline   Reply With Quote
Old 09-20-2007, 04:59 PM   #9 (permalink)
Sherlock SEL's Avatar
Date registered: Aug 2007
Vehicle: 420SEL, GS400
It's like an über bang bus
Sherlock SEL is offline   Reply With Quote
Old 09-20-2007, 05:18 PM   #10 (permalink)
AzimuthAviation's Avatar
Vehicle: 1982 380SE AMG euro (parted out) , 1983 300SD, 1984 500SEL AMG euro
A pilot I know uses his as a rolling "crash pad" and stays in it in the airport parking lot the night before a trip. Says he gets 25mpg in his with a diesel and it makes a hell of a camper. He's talking about getting some seats from some VW to put in it since he said to remove the MB seats is a pain and they weigh a ton.
AzimuthAviation is offline   Reply With Quote
Bringing sexy back ! mrmacp W210 E-Class 2 02-11-2007 10:20 AM
Mmmmmmm! Sexy! = P nutz4benz Off-Topic 11 12-07-2006 10:05 PM
One Sexy Limo Nutz 4 Benz W123 E,CE,D,CD,TD,TE Class 9 09-05-2006 11:58 AM
Sexy Neighbors josephanthony R129 SL Class 12 12-05-2005 06:50 PM
SHE IS SO SEXY! DEATHERAGE R170 SLK Class 10 02-05-2005 07:07 PM
