Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 06-22-2007, 03:57 AM   #1 (permalink)
Date registered: Jun 2007
Question Smoking problem on 413cdi Sprinter
I have a problem with a 413 cdi Sprinter, which smokes now and again (black smoke), on low revs. Has anybody else suffered with this problem, and if so, what was the outcome? Cheers!
ben stabler is offline   Reply With Quote
Old 06-23-2007, 03:30 AM   #2 (permalink)
Avantgarde 1998's Avatar
Date registered: Jan 2006
Vehicle: E200KOMPRESSOR
Bad diesel quality maybe..and maybe it's time to clean your fuel injectors and service the fuel pump.
MICHALIS :
Avantgarde 1998 is offline   Reply With Quote
Old 06-29-2007, 02:54 AM   #3 (permalink)
Date registered: Jan 2007
turbo shaft seal leaking , valve seal, cyl head gasket, piston rings, Cdi has high presure pump not injetor pump when injector are faulti also is hard to start and white smok
Benz the best is offline   Reply With Quote
Old 08-30-2008, 03:51 AM   #4 (permalink)
Date registered: Aug 2008
I have a similar problem, black smoke. Engine rebuilt last year smoking since then. replaced turbo last month and had injectors tested last week. Still smoking badly especially under load
kenyoung@iafrica.com is offline   Reply With Quote
Starting Problem For Sprinter 2o8cdi 2oo3 TEDAS W901-905 Sprinter 2 07-19-2007 11:07 PM
Air Conditiong problem on a 308D Sprinter merc308D W901-905 Sprinter 1 06-22-2007 04:10 AM
smoking problem allgoodian Vintage Mercedes-Benz 4 02-19-2007 12:20 AM
300D Turbo smoking problem shox75 W124 E,CE,D,TD Class 4 07-14-2006 07:08 PM
Wiring diagram 413CDI Sprinter 2003 mikejeffery W901-905 Sprinter 1 10-21-2004 10:05 PM
