» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 04-01-2007, 06:18 AM   #1 (permalink)
Date registered: Mar 2007
Query Drive wheel
Can anyone help with a problem I have with the drive wheel ?
Had a broken stud on the drive wheel. Mercedes said don't try to drill it out as it cnt be done and they would do the work for £400.00 for new half shalf seals and labour !!!!
So took van home drilled the stud , took me two minutes BUT the stud has gone inside the'hub'.
Can this do any damage whilst driving ?
ese139 is offline   Reply With Quote
Old 04-01-2007, 08:21 AM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 318CDi Auto
Send a message via Skype™ to radiotwo
Hello ese139
Yes ! but you don't say what van you have and how old, and does it have drums or discs.
you say the stud has gone in the hub ! so how are you going to put the new stud in ?
Radiotwo
radiotwo is offline   Reply With Quote
Old 04-01-2007, 08:46 AM   #3 (permalink)
It is a Merc sprinter 2004 with disc all round. The stud went right through so the new wheel stud just went on the wheel. This is what I mean when remains of the stud went through to the hub.
Old 04-01-2007, 09:58 AM   #4 (permalink)
Hi again,
I think it will have dropped in the break drum, so you will have to remove the
disk so the bit does not jam the brakes.
and bit you refer to is called a bolt and not a stud, a stud goes in from the back and you put a nut on the outside of the wheel.
Old 04-01-2007, 10:51 AM   #5 (permalink)
I need to talk to you direct . Can you email me on ese139@hotmail.com ?
thanks.
Old 04-01-2007, 12:31 PM   #6 (permalink)
I have sent a email
Radiotwo
Old 04-01-2007, 01:25 PM   #7 (permalink)
Hi ese139
I know these are not for a van, but shows the discs !
eBay Motors: Rear Disc Brake Rotors Mercedes Benz 500 560 sel 126 (item 300089729510 end time Apr-08-07 11:42:02 PDT)
Radiotwo
Do I Not have All Wheel Drive?? Benzlova W163 M-Class 8 10-25-2006 01:41 PM
129 ebay wheel seller query.................. shrimpton R129 SL Class 10 07-18-2005 11:10 PM
Front wheel drive or Rear wheel drive? JonnyBravo R171 SLK Class 3 10-10-2004 07:06 AM
Newbie Query: W124 Offset Query Rim Width happy_jon The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 07-13-2003 05:16 AM
lots of new ML owners, Let's discuss all-wheel drive, 4wheel drive and full time 4wheel drive.... guy W163 M-Class 10 12-09-2001 07:08 AM
