I HAVE THE SAME PROBLEM WITH 2 OF MY SPRINTERS 208CDI 2003 MODEL, UNTILL STARTED WINTER THEY WERE DRIVING AND STARTING VERY NICELY, NO PROBLEM AT ALL, BUT WHEN STARTED COLDER AND BECME LESS THEN 5 DEGREES, ITS APPEARS PROBLEM TO START WITH STARTER IN MORNING OR LATER DURING DAYTIME, IF USING A ROPE AND TOW THEM THEN STARTING AT ONCE THE WHEELS TURN ENGINE, BUT TO START WITH STARTER IT IS IMPOOOOSIBLE.
I CHANGE FUEL FILTER, CHECKED FOR FUEL LEAKAGE OR AIR IN SYSTEM, CHECKED GLOW PLUGS EVERYTHING SEEMS FINE
ITS LEFT JUST FUEL INJECTORS I GUESS,
ALSO MY GUESSING IS IF THERE IS ANY DIFFERENCE IN MODEL MADE IN fRANCE WHERE IS MUCH WARMER ALL TIME DURING A YEAR, NOW MY SPRINTERS DRIVING IN MUCH COLDER CLIMATE IN NORWAY
I experienced similar problems with my other car. If the fuel filter does not seal tightly it could be that due to colder weather air could be sucked into the fuel systen already in the filter. That is why the car starts, but stops quickly again. Just tighten the fuel filter a notch when the engine is cold.
Hope is works.
HAD SOMEBODY ELSE SUCH PROBLEMS WITH CDI ENGINES
THANKS FOR ANY ADVICE
SINCERELY
I've got excatly the same problem,how did you fix yours
