» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 01-11-2007, 11:36 AM   #1 (permalink)
Date registered: Jan 2007
308 CDI 2.2 won't start - hot or cold
Hi all!
my Sprinter CDI 308 2.2 was running fine until one day I simply turn the key off. When tried to start it again just 10 seconds after this it couldn't start. I crank it til the battery went flat but no luck. After this someone gave me the idea of spaying some easy start into the air pipe and...miracle - it started straight away. I drove back home with no problems but as soon as I turned the key off and tried to start it, it would get going without easystart. I borrowed a carsoft interface to check the ECU and found out that there ware 5 errors stored on it. I erased them and tried to start it but the problem remained. Then a changed the fuel filter together with the water sensor (the one that goes underneath the filter), stack the pipe which feeds the filter in a bottle full of fuel (just in case there something wrong along the system from the tank to the filter) but the problem was still there. Then removed the plastic cover to expose the common rai, undid the pipe which feeds it, cranked the engine and found out that the pipe is bleeding. After that I undid each one of the 4 pipes feeding the injectors but found out that there is fuel there as well. The engine still sounds great but won't start without easystart. No errors are stored on the ECU neither. Have anyone had similar problem and do you guys have any suggestions of what could have caused it?
gagarin is offline   Reply With Quote
Old 01-11-2007, 11:55 AM   #2 (permalink)
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 111CDi 2004
The hot film mass air flow meter could be at fault?? It's the thing you are squirting easy start into.
adamuk is offline   Reply With Quote
Old 01-12-2007, 01:38 PM   #3 (permalink)
zx9
zx9's Avatar
Date registered: Oct 2006
Vehicle: 2000 108CDi, 99 A4 1.8T, 98 ZX9R, 84 GPz1100, 76 Range Rover 2dr.
My bet would be the o rings in the pressure regulator at the end of the high pressure fuel rail. On starter motor the high pressure pump can not build up enough pressure/ volume to overcome that lossed through leaking o rings. With the engine running on easy start the pump turns over fast enoung to pressurise the fuel rail and injectors.
Regards
ZX9
zx9 is offline   Reply With Quote
Old 01-16-2007, 09:44 PM   #4 (permalink)
Regards
ZX9
Your bet wins m8 We got it changed tonight and started straight away. Now I have to call mercedes garage to cancel my apointment. Thanks!!!Nice one...
Old 01-17-2007, 01:42 AM   #5 (permalink)
Mate you have to test your injectors with a special tool, injector are returning too much fuel and they are not holding pressure to able the vehicle to start
Benz the best is offline   Reply With Quote
Old 01-23-2007, 11:10 AM   #6 (permalink)
Regards
ZX9
Hello
I had the same problem with a 211 2.2 cdi sprinter, but i don't found the pressure regulator. Sorry, can you send a photo, where i found the fuel regulator?
Thanks.
ktbstudio is offline   Reply With Quote
Old 02-03-2007, 03:20 AM   #7 (permalink)
I have found the regulator, and i changed the 2 o rigns. I remounted the regulator, for the first time, the engine starts normaly, then at the 2, and 3th start starts after a lot of crank, and at the 4th time, don't starts.
Probably the pressure regulator is failed?
I mounted a pipe to the end of the regulator, where is the 2 o rings, but the regulator don't keeps the pressure. After 10 seconds the vacum pressure is 0.
Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 9 10-17-2009 05:56 PM
Cold Start/Hot Start/Idle joesette W124 E,CE,D,TD Class 6 01-01-2007 08:18 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL Class 7 01-02-2006 06:33 AM
93 190e AC is Cold, then blows hot, Heat blows hot, then cold hippiechick W201 190 Class 8 10-20-2005 11:35 AM
1987 W124 300E hard to start hot or cold Any ideas. rcs hawaii W124 E,CE,D,TD Class 1 12-15-2004 07:31 AM
