» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 01-06-2007, 06:26 AM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 1994 sl500
sprinter. faults, servicing tips.
i wrote this when bored one rainy sunday afternoon as an ebay revue. it may help someone, you may think its a load of tosh. let me know!
Ok. Im writing this as a sprinter fleet owner and delivery driver that has done over 500,000 miles in sprinters!
There are many variants available as shown below.
swb models approx 7ft behind bulkhead to rear doors.identified by one rear panel
mwb approx 10ft to doors. identified by 2 rear panels
lwb approx 14ft to doors. identified by 3 rear panels.(huge cube but lower payload due to higher body weight)
2 roof heights low and high (standard roof, tall enough to walk around in without hitting your head)
The model numbers represent the gross vehicle weight (thanks to andrew for correcting me)
Normally the 2-- series was a 2590kg, but could be uprated to a 2800kg GVW - mainly low roof models favoured by builders etc.
the 3-- series has a 3500kg gvw. the most commonly seen.
the 4-- series are twin wheelers 4.2 ?? tonne but can be downrated with new springs and re test. (less room between wheel arches inside too)
the sprinter 3-- series are the most common seen on UK roads. usually high roof models favoured by couriers etc.
The older models 308, 310, 312: diesels
Having test driven a 308 i found it only really suitable for local work, ie carpet fitters etc as it was a bit underpowered for loaded motorway work only a 2.3litre engine! roughly 80hp
The 310 d. 2.9 litres of turbocharged diesel producing a leisurely 110 hp or thereabouts. Available in short , medium or extra long (14ft behind bulkhead to rear doors). This was my first sprinter! Driven 125000 miles in a year. Never let me down! less to go wrong, no abs, slip diff etc on most.
312d. again 2.9 litres leisurely producing 120 hp or thereabouts. Again available in all 3 lengths.has abs, asr etc on this model which makes it a bit safer. a preferable buy if you can find a well looked after one.
I still drive a 312 today. I regard it as more comfortable and leisurely smooth than the newer models to drive due to its torque you rarely have to change down unless into traffic.
Dont write these vans off as old hat, they are still very capable, extremely comfortable for long journeys (believe me sometimes i drive 18 hours a day! and in my old transit i couldnt do 6)
Good points: comfort, load space, Smooth gearbox and underworked engine.
Bad points: Sprinters rust! chassis and underside is well protected and stay good but the bodywork paint isnt the hardest and stone chips and scratches soon blister and scab, although superficial this can look ugly.
Sprinters eat front lower ball joints: if doing multi drop local youl probably need to replace these annually, motoway milage every 3 years at a push (from experience my fleet which does mainly motorway miles has lower ball joints every 2 years. The part costs £8 factored but you really cant do this yourself as it requires garage facilities. We pay £150 a pair fitted but our mot station charges £180 a side!
Avoid cheap budget tyres. why? they wear out too quick! I run 4 sprinters. A budget tyre costs roughly £50 fitted.Life span roughly 20- 40 000 miles. A bridgestone duravis tyre costs roughly £70 fitted (but i have a pair on the front of my 312 that have done 190000 miles and arent done in yet. what does that tell you?
stay on top of it with a touch up stick. The body is big and quite expensive to get re painted!
tips: Look for a well looked after example. Service printout history although nice just tells you whats gone wrong in the past. sprinters dont have timing belts so thats good news, ive never had timing chain problems! Change the oil and filter every 6000 miles. i know the service period is longer but the oil is stinking after 6000 miles. Roughly £20 for peace of mind
Things to look out for: Noisy fan belt. usually alternator pulley sprag bearing seizing. (it will drop off soon and leave you stranded) (only £32 from mercs so get it changed) also the hydraulic damper unit can cause this along with a worn bushing, cheap and easy to replace.
Rattling from gearbox area. Flywheel dual mass unit. £500 approx to buy
Vibration when driving. No.. we thought propshaft too but it turned out to be the expensive flywheel . see above.
Other than that there are 2 main points to note (which means crawling under the van)
There is a brake compensator at the rear under the van which allows more back brake when loaded. this requires regular lubrication. If it seizes in the loaded position and you hit the brakes hard the back wheels can totally lock up. ( ive read a few crash reports of this so make sure its checked regularly) it is an open unit and not protected from spray, road salt etc. Solution make sure its free and litterally plaster it in grease
The same goes for the hand brake mixer which again is an open unit which tends to seize up, usually noticed first when handbrake doesnt release properly when put off.
New models sprinter 311, 313, 316 diesels short, medium and long wheel base
Watch the payload you put in them, the long wheel base only has approx 1000kg with full fuel and a driver. You find this out for the first time when pc plod pulls you over and takes you to a weighbridge then kindly takes you to court and issues a hefty fine! again through experience... doh!.
some lutons etc with tail lifts are huge inside but you could only fill them with polystyrene. Use a public weighbridge to find out what you can carry. Go there with no load on but with normal driver and full fuel. You will be amazed at the result.
311: The most popular sprinter on the road now.(mainly due to it having the lowest new buy price) check the specs, there are a lot of imports of this model about.
2.3. litre 4 cylinder injected td pushing out 110 hp
313 2.3 litre 4 cylinder injected td pushing out 130hp rarely for sale because theyre so good. Long distance couriers favour these because you have a bit more hp and a more relaxed drive
316 2.8 litre 5 cylinder injected td pushing out 158 hp . Like rocking horse droppings to find because of very high new price not many around (but i have one :-) slightly less payload due to extra engine weight but so torquey that they are a pleasure to drive, especially when your getting boxed in on the motorway and you need fast acceleration, just put your foot down and it pulls like a train. fuel burn averages out about the same as 311 and 313. These also can have so many extras fitted so check the specs.
The main differences between the older and new models:
Gearstick is dashboard mounted on new models (but beware the cables to gearbox need regular maintenance or they stretch and make gearchange sloppy. if left they can leave you stuck in 1 gear which isnt much fun)
New headlamp layout on the front and an air intake mounted into offside wing which looks cool
To be fair to mercs there is probably a lot of other things they put into it but from a driving / owning point of view hardly any difference (apart from a pen holder and a can holder which pops out of ashtray)
fuel burn on all the sprinters i have driven averages out approx the same . expect 450 to 500 miles from a tank fill of 75 litres giving a reserve of 5 litres (most have an 80 litre tank) which is enough to drive in 1 hit.
Bad points:
The bad points on the older vans as above still apply. ball joints, brake compensator etc
additionally they seem to eat heater glow plugs which can be very awkward to change.
Electronic injectors dont seem to last too long and you cant just replace them. you then need to go to mercs and have them callibrated by number as they are precision metering units. A worn injector can cause over fuelling to a cylinder and crack pistons which is engine out and replace...ouch!
Engine management can be a pain. if it detects anything wrong it can put you into limp home mode which is just that. lose enough power to just get up a hill in 2nd gear max 3250 revs. No fun if your 400 miles from home when it happens. The older models rarely seem to suffer this!
Servicing tips for all models:
regular oil change at 6000 miles
lubricate the wiper arm output shafts otherwise they wear and the wipers squeel when on..and i bet you thought it was the blades!
check and lubricate brake compensator unit and handbrake mixer.
have brake disks removed and inspected for cracking on inner section, always seems to happen on inside where it cant be seen easily
Lubricate the spare wheel hanger unit or you wont remove the spare when you need to.it can seize solid (use vinegar to penetrate the rust if seized)
Errors and ommisions excluded in my appraisal. Its written from experience of sprinters not from full technical knowledge but if you find huge mistakes let me know. if you find it helpfull. buy me a pint! (loads of people contact me for help with sprinter faults, il help where i can but i dont work for mercs! i was a mechanic for 8 years so have a good knowledge of lots of bits and pieces that i have come accross as a mechanic and fleet owner only)
battwell is offline   Reply With Quote
Old 01-06-2007, 08:31 AM   #2 (permalink)
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 111CDi 2004
All good mate... thanks for the info. There's so little information about. Have you ever tried getting anything off the MB website and you will see what I mean.
Cheers
Adam.
adamuk is offline   Reply With Quote
Old 01-13-2007, 01:32 PM   #3 (permalink)
Date registered: Jan 2007
Thumbs up
Many thanks Battwell for the information.
Forwarned is forarmed.
I thought I had done well on my Continental
Vancos at 47,000 miles so I must look
into these Bridgestones.
Also this "engine assist" told me to change
oil at 24,500 miles and 46,000 miles, so
perhaps I will change it a bit more often then !
Thanks again,
CD
cornish dragon is offline   Reply With Quote
Old 01-14-2007, 05:58 AM   #4 (permalink)
Vehicle: 1994 sl500
re oil changes
i use mineral oil in my vans and have always changed at 6k miles.
but. there is a very intersesting article on here re mobil 1 oil. well worth a read!
re the tyres, my mate owns a tyre bay and doesnt offer these to customers since he fitted them to mine 3 years ago. we wont use anything else now.
Old 01-14-2007, 10:40 AM   #5 (permalink)
Date registered: Oct 2006
Cornishdrake, I use the Vanco Contact on my 115 vito and get the same kind mileage (once I had sorted the steering geometry out)
Must ckeck if those Duravis are brought into RSA.
batwell - are you serious when you say 190 000 miles??? Do they offer decent grip the old "soft tyres plenty grip, hard tyres feck all grip but long miles " would seem to apply
Batwell, top write up mate, having a beer for you.
rufus is offline   Reply With Quote
Old 01-17-2007, 11:55 AM   #6 (permalink)
Vehicle: 1994 sl500
yep. 202000 miles now on the front of my 312 sprinter. never even had to re balance them. (and no i dont drive with so much rear load that front wheels are off the ground) i know the exact milage they went on, have the receipt here!
they still have an even 5mm tread left!
Old 01-18-2007, 03:46 AM   #7 (permalink)
how do you know if your injectors are faulty, what are the signs
xfiles is offline   Reply With Quote
Old 01-18-2007, 01:22 PM   #8 (permalink)
Battwell, please can i ask what sort of
mileage do you get on the back tyres ?
Funnily enough all four of my tyres are
about the same just coming to the ware
bars at 47,500 odd, may be another
couple of k in them.
Would your mate with the tyre company
fit my van up with Bridgestones if I
mentioned your name
at that sort of longlivity it is worth a
drive up to wales ( especially as Jethro
Tull are playing there in the next couple
of months...........
I did a search and couldn't find these
tyres generally around.
CU
CD
Old 01-19-2007, 03:25 AM   #9 (permalink)
Vehicle: 1994 sl500
re bridgestone duravis tyres for sprinter
i dont think the rears will last that sort of milage, to be honest i only put the duravis on rears last year... still like new now.
up until then i had run reard on budgets which are ok but wear quickly.
on my 316 i have michelins which came on the new alloys. These are wearing fast, noticable at 10000 miles!
re the duravis, they were ordered from bits (tyre distributors) who i believe are the main nationwide tyre supplier. try ringing them to see if yyour local depot is served first otherwise im sure i can arrange them at my local depot. the last lot i ordered took about 3 weeks to arrive.
Old 02-13-2007, 02:22 PM   #10 (permalink)
Date registered: Feb 2007
brake light
cheers battwell
top info
my ball joints are clanging like no mans business!!
my 311 cdi has hardly any power, brake light showing on console do you reckon power loss due to this. any info appreciated
cheers
abbas 580
abbas 580 is offline   Reply With Quote
roof faults wilkoo2 R170 SLK Class 0 08-02-2006 08:37 AM
New Faults rab538 W163 M-Class 1 07-04-2006 11:14 AM
w203 faults delb0y General Mercedes-Benz 0 05-02-2006 05:15 PM
Ultimate Windsurfing Van - Freightliner Sprinter Van Dodge Sprinter Saigon76nyc W901-905 Sprinter 3 10-06-2005 12:17 PM
electrical faults drk. grn. 400se W140 S-Class 4 03-15-2004 10:59 AM
