» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 05-20-2006, 12:45 PM   #1 (permalink)
Sprinter daytime running lights disable
Hi,
Anyone know hot to disable this. This came standard on my Freightline RV. It is not required in my home state.
RT
rtabcum is offline   Reply With Quote
Old 08-04-2008, 08:51 PM   #2 (permalink)
Date registered: Aug 2008
Vehicle: 96 S600 sedan w/ ADS-II; 02 Sprinter 2500 Van 158" hi-roof cargo w/ AC, courier package, Espar unit
Hi. There are two relays located under the driver's seat riser (at the front) that need to be removed (with battery disconnected, press brake pedal to discharge SRS system). You need to remove the two torx screws and move the particleboard cover a bit and possibly unplug the seatbelt receiver cable. They should be clearly marked.
The service manual only describes this procedure in general.
Alternately, there is supposed to be a setting in the instrument cluster computer to turn off the DRLs but you would need to go to a dealer.
Regards.
djc126 is offline   Reply With Quote
