good day people,
i have here a sprinter that is giving me some problems, when starting the engine in the display it say that the gear is in neutral, when putting it in reverse or forward the neutral light is than flashing and the car will not go in reverse or forward, now i found that inside under the seat fuse 8 (40amp)was blown i replace this but still the car will not go in reverse or forward. do i need to reset this with a computer??
regards
john
Can you get the vehicle to drive at all ?
If not you have problem with your hydraulic pressure, you need to check the ssg relay under the driver seat the contacts stick and burn out the hydraulic pump
