» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-905 Sprinter
Old 05-26-2004, 08:48 AM   #1 (permalink)
Date registered: May 2004
Send a message via Yahoo to tommyK
Power Take Off for the Sprinter
I understand there is a Power Take Off available for the Sprinter in Europe, but I cannot find anything on it in the States.
A PTO is vital to my decistion to purchace and modify this panel van for my uses.
Presently, I have a direct drive carpet cleaning setup, that is powered by the van engine and uses the coolant heat exchanger to take the heat off the engine before it goes to the radator. It's an effecient setup and rarely needs service, but the fuel consumption is putting me out of business. I carry 200+ gallons of water and sometimes 400, plus the weight of equipment. With this 305 chevy setup, I get 8 to 10 mpg.
With what I hear and can see, the Sprinter will be perfect for my uses, and help me be profitable. I've spoken to many who have a Sprinter and cary lots of weight and I hear that they are getting 20 to 25 mpg. If this is true, and it sounds like a fantasy, I really need to do this.
The manufacturer of my equipment is not interested in this conversion as they tell me they are building as many rigs as they can and do not wish to retool for a different vehichle. I know they will only be interested after I am successful. They are willing to give me some specs, but that's about all.
What I have now is an old Checy Van which uses a belt & air conditioner clutch mechanism actuating a direct drive shaft drive which goes through the engine cover to my machinery behind the drivers seat. With the current configuration, the engine runs at 1,750 rpm when my equipment is engaged.
As there is no room for the shafts, I can see no way to use this same hookup on the Mercedes Sprinter, so I need to investigate the PTO options that would be taken from somewhere off the transmission under the vehicle.
I am willing to import the parts myself to make it possible. I just need some specs so I can work out the design.
Our local dealership in Charlotte, NC has been useless in finding any information for me. He just knows its available in Europe.
Wandering the interent, I found a service manual page that mentions the PTO for that drivetrain. However it was unclear as to what kind of design it is.
I need to know if it's designed for a belt, or gear, or hydraulic or whatever. I'd need to know where it's located so I can design a way to use it.
Another detail I will need a chart showing the HP ratings at a variety of RPM's and knowledge of what is ideal for this engine if it runns at a steady speed for extended periods of time.
I am told that a diesel engine does not produce the same high heat that a gas engine does, so I will need to also modify how I transfer heat to my equipment. I need to operate at about 195 degrees, but I have options to boost the heat, should I need. There are several options to boost the heat. Taking waste heat off a blower mechanism which runs at 300 degrees, or a simple wrap of the exhaust pipe.
Is there a BTU rating for this engine I can use that will help me figure out what to modify, or if I need to at all?
Any information you can provide may be helpful.
Thank you,
Tom K
Charlotte, NC USA
tommyK is offline   Reply With Quote
Old 06-01-2004, 08:56 AM   #2 (permalink)
Date registered: Jul 2003
Vehicle: 2003 112CDi Vito Van
RE: Power Take Off for the Sprinter
Hi Tom
I have driven one of the earlier Sprinters (2.3l Diesel) and was impressed with the power and performance. The new units would be awesome.
With regard to your Cleaning unit, I've seen this type of gear in a Toyota Hiace. Have you considered fitting a stationary engine for the cleaner and perhaps an auxilary diesel water heater, in lieu of the expense and modification exercise? This could all be built on a sled, allowing removal for service and extra functionality of the van.
Just a thought.
Rob K
RHKVito is offline   Reply With Quote
Old 06-02-2004, 04:11 PM   #3 (permalink)
clocka's Avatar
Date registered: Aug 2003
Vehicle: V220 CDI Ambiente
Hi
The Mercedes CDI diesel engines produce very little wasted heat.
My V-class which has a 2.2 litre CDI engine has a 5000Watt water heater fitted as standard (heater booster) to warm the engines water when the weather get cold.
Phil
clocka is offline   Reply With Quote
Old 10-21-2004, 11:25 PM   #4 (permalink)
Date registered: Oct 2004
the sprinter comes with two options for PTO but the PTo that you required has to be ordered direct from the factory in germany....the sales code is N07 that is a direct drive via a flange off the back of the gearbox
The Guru is offline   Reply With Quote
