Heater stopped blowing - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-19-2011, 12:43 PM Thread Starter
4themasses's Avatar
Date registered: Oct 2008
Vehicle: 2002 CL55 AMG, 2009 E63
Quoted: 7 Post(s)
Wife just called and said the heater was blowing on and off then just stopped....no heat now. I'll look at it when I get home to see if rears are working. Anyone have this happen?? Anything electrical to look at? Relay?
Edit:
I should clarify and add that I believe it is the fan/fan speed, not the heater itself.
2009 E63 AMG
2002 CL55 AMG
2011 C300 4MATIC - Gone
1986 Mustang SVO- Gone
2002 Navigator - Gone
2006 R350 4MATIC - Gone
2001 E55 AMG - Totaled
1992 500 SEL - Gone
4themasses is offline
post #2 of 9 (permalink) Old 04-19-2011, 09:58 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
The front blower and the rear blower (located in the console I presume) are both not working.
I'm assuming there is one located in the console since the rear heater controls and vents are on the rear of it. I do believe there are two seperate fans.
Anyone have any ideas?
I'm also assuming right now this isn't a water/hood vent problem if both are not working. I haven't dug too deep into it yet.
Fan never made any unusual noises prior to just stopping.
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
post #3 of 9 (permalink) Old 04-20-2011, 06:57 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
Was able to pull cover down and yes it was wet. Pulled the blower motor out, turned upside down and drained the rest of the water out. Potomac German Auto has several used replacements from $85 to $175.
For reference if someone needs it:
http://www.benzworld.org/forums/w164...wer-motor.html
Interesting to me that the rear blower isn't funtional.
FYI, for those who may not be aware of this. There is a fuse diagram fold out, spare fuses, fuse puller in the spare tire center piece. Also the rear fuse box is to the right of the spare under a cover.
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
post #4 of 9 (permalink) Old 04-30-2011, 03:54 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
Replaced blower motor with a used unit ($100 shipped) and everything works now. I cleaned out the drain hole that is under the hood vent. Looks like it will fill up with about 10" of water before it will start spilling over into the car. Takes less than 2 minutes to remove two clips, remove main plastic attachment, stick finger in drain to clear out (just push finger thru). Will save you this whole ordeal.
Side note. There is a long plastic connector with about 8 or so small orange wired connectors going to it that is attached to the panel under the blower moter. If you disconnect these you car WILL NOT start.
FYI
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
post #5 of 9 (permalink) Old 04-30-2011, 04:13 PM
AsianBlackR350's Avatar
Date registered: May 2008
Vehicle: 08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
Quoted: 6 Post(s)
FYI
It is good to hear you fixed the problem :thumbsup
Does your rear vent work too?
2008 R350 4 Matic w/P1 package/7 seater/Ipod/Front heated seats/ Retrofitted OEM GPS Navigation / 10.2" LCD Overhead Mobile Video system w/ 30 Sega Games, Wireless HeadPhone, hard wired to OEM HK sound system, B/U Camera integrated W/ 6 Disc DVD Changer , hard wired Passort Escort X8500, Mtec HID, 17 SMD LEDs city lights.
2007 Acura RL w/ tech package, A-spec body kit, Deck lid spoiler,TVandNAV2go,USA spec Audio, 18 " Wheels, Wooden steering wheel, Wooden shift knob
AsianBlackR350 is offline
post #6 of 9 (permalink) Old 04-30-2011, 04:19 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
Yes it does. The blower has twso plug that attach to it. I'm assuming one goes to the fan in the center console. If the main isn't working, that will not either. Key to this whole deal is to make everyone aware to clean this drain out. Literally takes two minutes. Make a mandatory check when you do the oil or something. I know I am!!
I mean you can look down in there and see if there is water or not. Very obvious!
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
post #7 of 9 (permalink) Old 10-04-2011, 12:09 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
So to follow up on this thread (see.....people do COMPLETE threads to help others)
http://www.benzworld.org/forums/w251...con-red-2.html
Please make checking this drain part of your MB ritual of checking fluids etc. If not, you will soon be doing as I have done. CHECK FOR WATER ON THE PASS FLOOR!
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
post #8 of 9 (permalink) Old 10-04-2011, 04:08 PM
Date registered: Feb 2008
Vehicle: 2006 R350
Some more info on blower issue - with a twist
Looks like I'm one of those R owners who did not get the message in time to clean the drain. I'm sure it's the season (fall) for blowing the blowers.
My difference is that the blower did not quit but rather decided to work overtime and drain the battery after shutting the car off. I noticed that it seems to work as usual when the vehicle is in operation.
As I could not get the replacement part quickly enough (dealer in Canada wants 606.00 dollars for the part when on line new goes for roughly half of it) I decided to save the battery by adding a on/off switch to the blower's harness. Now we just have to remember to turn it off when the car is parked and back on when need to use AC.
Does anyone have opinion if this could work long term (beside the annoyance of having another switch)?
richardmb is offline
post #9 of 9 (permalink) Old 10-05-2011, 02:29 PM Thread Starter
4themasses's Avatar
Quoted: 7 Post(s)
What I can tell you is that I bought a used blower assy. form Potomac German Parts for about $140. Their parts come with a 6 month warranty.
FYI
2009 E63 AMG
2002 CL55 AMG
1992 500 SEL - Gone
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
    heater always blowing hot wayner118 V-Class 8 10-30-2013 03:28 AM
    Heater not blowing air??? tygger W124 E,CE,D,TD Class 12 12-23-2011 12:28 AM
    '98 SL500 A/C Stopped Blowing Cold Dimitris R129 SL-Class 13 09-29-2008 10:35 AM
    300D Heater stopped blowing hot homeslice0229 W123 E,CE,D,CD,TD,TE Class 1 12-28-2007 11:04 AM
    Heater blowing on and off 2001merc W210 E-Class 1 12-11-2007 10:57 AM
