R350 Spark Plugs - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 01-24-2011, 04:32 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
They're cheaper at this Mercedes dealer
https://www.getmercedesparts.com/oem...des-parts.html
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #12 of 17 (permalink) Old 02-04-2011, 07:59 PM
Date registered: Nov 2009
Vehicle: 06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
What do you guys have to say about upgrading since I have performance tuning?
2006 R-350 V6 Silver 63,000 Miles
Michelin Latitude Tour HP R19
Hitch, 0W-40 Mobil 1 European, I Pull The Drain Plug Every 10,000 Miles And Change The Filter
Lucas Fuel Treatment About Every 1,000 - 2,000 Miles.
Modified Grille = Ram Air Effect In Intake.
K&N Air Filters
ECM tuning
Choosing an air filter:
http://www.benzworld.org/forums/w251...ml#post4443597
smokersteve is offline
post #13 of 17 (permalink) Old 02-06-2011, 05:21 PM
I was trying to replace mine on a R500 while I took out the air box after I changed the air filter. The space is very tight and the plugs are also at an angle to take out. I eventually gave up on it since I need to change 16 of them and don't feel like struggling through it.
Good luck.
supernsx is offline
post #14 of 17 (permalink) Old 01-27-2013, 10:19 AM
Date registered: Feb 2009
Vehicle: 07' R350, 03' Jaguar STR, Recently acquired 03' s55 AMG
Does anyone know if you need a special MB tool to remove the boot plugs in order to change out the spark plugs? Or is it just a simple remove the airbox and pop out the boot plugs to get to them?
I have 122k on my 07' R350 I'm pretty sure the plugs are over due
Merc79 is offline
post #15 of 17 (permalink) Old 01-27-2013, 05:02 PM
eric242340's Avatar
Quoted: 309 Post(s)
They are held by two hex head screws, straightforward job.
ERIC.
eric242340 is offline
post #16 of 17 (permalink) Old 02-03-2013, 07:06 AM
Thank you soo much for that info and description By the way what software are you using to pull up that description from?
Merc79 is offline
post #17 of 17 (permalink) Old 02-03-2013, 07:15 AM
eric242340's Avatar
Quoted: 309 Post(s)
The document is very difficult to use unless you are a trained tech but some people seem to use it without too much problem, here is a link that will inform you;
Mercedes EWA net WIS, repair manual, Trucks / Buses Repair
ERIC.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
    how to replace spark plugs and where are the plugs in 1994 c280? poorsenti W202 C-Class 4 05-02-2011 08:30 AM
    Spark Plugs & Spark Plug Wire Reccomendations danger450 R170 SLK-Class 2 02-19-2009 06:02 PM
    What Spark Plugs? Spark Plug gap? Spark plug used? hilarushi W210 E-Class 4 03-29-2007 11:42 PM
    Glow Plugs or Spark Plugs?? Are they the same thing? sudha W123 E,CE,D,CD,TD,TE Class 4 11-30-2005 10:27 PM
    Spark plugs, who's work best, and how about Platinum or Iridium plugs? Bruce R. W201 190-Class 2 07-11-2003 04:25 AM
