Service Coupon - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-09-2010, 10:14 PM Thread Starter
Date registered: Nov 2009
Vehicle: 06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Service Coupon
I recieved a service coupon for "A" service special. What is service A?
http://images.mmserver.com/display_c...343-7EA157&p=7
2006 R-350 V6 Silver 63,000 Miles
Michelin Latitude Tour HP R19
Hitch, 0W-40 Mobil 1 European, I Pull The Drain Plug Every 10,000 Miles And Change The Filter
Lucas Fuel Treatment About Every 1,000 - 2,000 Miles.
Modified Grille = Ram Air Effect In Intake.
K&N Air Filters
ECM tuning
Choosing an air filter:
http://www.benzworld.org/forums/w251...ml#post4443597
smokersteve is offline
post #2 of 11 (permalink) Old 09-10-2010, 04:10 AM
Date registered: Feb 2008
Vehicle: 1987 560SL - Signal Red, 2014 ML350 - Diamond White, 2016 Ford Explorer - Magnetic (company car)
Quoted: 55 Post(s)
It is the "small" service, 10, 30, 50k etc, if I remember right.
The B service is 20, 40, 60k etc, this all chanegd in 2008 before they had A, B, C, D, E etc
2008R320 is offline
post #3 of 11 (permalink) Old 09-10-2010, 10:34 AM Thread Starter
What is in the small service?
K&N Air Filters
ECM tuning
post #4 of 11 (permalink) Old 09-11-2010, 10:15 PM
Date registered: Mar 2010
Vehicle: 2006 Alpine Rain R500
The 'small' service is basically an oil and filter change, top off fluids, set tire pressures, visual inspection, reset service computer. I notice your coupon is from the Sac area dealerships. If you decide you want to find a good MB independant shop, let me know. My shop is in the South Sac area.
2003 Land Rover Discovery
2002 Saab 9-5 Aero
2010 Lexus RX350
alvin18 is offline
post #5 of 11 (permalink) Old 09-12-2010, 08:55 AM Thread Starter
I would love to know of one, Thank you very much for your offer
This is the one we got the R350 from
4747 Granite Dr.,
Rocklin, CA 95677
K&N Air Filters
ECM tuning
post #6 of 11 (permalink) Old 09-12-2010, 07:44 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
This is the correct sequence--original poster can now check maintenance booklet that came with car to learn the full details.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #7 of 11 (permalink) Old 09-13-2010, 04:17 AM
Quoted: 55 Post(s)
Thanks Ikchris, the basics in mainetnance can also be found here;
Mercedes-Benz - Home of C, E, S, CLK, CLS, CL, SLK, SL, SLR, R, GLK, M, GL, G Class - Service and Parts Maintenance
2008R320 is offline
post #8 of 11 (permalink) Old 09-14-2010, 07:08 PM
4747 Granite Dr.,
Rocklin, CA 95677
What a coincidence, we got our R500 from MB of Rocklin as well.
Here is my shop info
Star Motors
2680 Florin Rd #103A
Sac, CA 95822
(916)421-4007
I used to be a service advisor at MB of Sac, but opened my own shop 2 years ago. Feel free to call if you have any questions, ask for Alvin.
2002 Saab 9-5 Aero
2010 Lexus RX350
alvin18 is offline
post #9 of 11 (permalink) Old 09-14-2010, 07:10 PM
Regarding the service schedule, the maintenance book makes it look so easy, but in reality, when you get a chance to open that submenu in the cluster, it actually lists a group of service items, some are needed some are not, so this is the reason it is so hard to give an actual quote for the service.
2002 Saab 9-5 Aero
2010 Lexus RX350
alvin18 is offline
post #10 of 11 (permalink) Old 09-28-2010, 04:13 PM
Date registered: Feb 2010
Vehicle: 2006-R350, 2003-C230, 1999-ML320, 2000-S430 at present.
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
The MBUSA site has this to say: "B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years." I believe the FSS is described in detail in your Operator's Manual.
In case you're interested, here's what they say should be done:
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
ASHOKA8350 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
5% Off +$10 Off Coupon FCP Euro FCP Groton 0 01-08-2009 03:43 PM
Help With Finding $99 Oil/Filter Change Service Coupon smarten W164 M-Class 7 11-17-2007 07:02 AM
$25 off service coupon GregW / Oregon W164 M-Class 2 08-29-2006 06:08 AM
c coupon vdubpower W203 C-Class 5 11-30-2004 02:13 PM
