engine oil capacity - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-25-2010, 02:13 PM Thread Starter
Date registered: Jan 2008
engine oil capacity
I have changed the oil on my car now 3 times, and I know that the pan holds somewhere around 9 to 10 quarts. The first time I changed it I put in 9 quarts, I wasnt sure. The second time I put in 8 quarts, and this time I put in 7 quarts. I drained the oil with the car being leveled to make sure that all the oil was out. The dash says that it doesnt need any oil even after 7 quarts in the pan. Do I need to add all 10 quarts? I also noticed that there was oil sludge were you add the oil. It wasnt burnt , but a thick like paste or better yet malt. Has anyone noticed this when adding oil. At what point does the level say to add oil-how many quarts 5 to 6 quarts. Does anyone have any ideas. Thanks
rjg914 is offline
post #2 of 5 (permalink) Old 03-25-2010, 07:07 PM
Date registered: Feb 2010
Vehicle: 2006-R350, 2003-C230, 1999-ML320, 2000-S430 at present.
If you are talking of R350 Mercedes, it takes 8.5 US quarts of Synthetic oil. This is what is recommended by the Mercedes Benz. Recommended synthetic oil is Mobil 1. I use Mobil 5-40 or 0-4o.
Regarding oil sludge, thick paste like malt, I did not understand your question. Did you find it in the bottom of the new synthetic oil or in the draining oil.
ASHOKA8350 is offline
post #3 of 5 (permalink) Old 03-26-2010, 03:36 AM
Date registered: Jun 2009
I never measure the new or used oil as that is a waste of time and its very dirty. I suggest you to fill up the oil until it is one the "high" mark then start the engine. Usually it will go down a little, refill it up to the "high" mark again and it should be fine.
tabocat is offline
post #4 of 5 (permalink) Old 03-26-2010, 11:32 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Owners manual specifies oil change quantity. It's ridiculous to consider this a "mystery." Need a manual? 800.for.merc
There is some tendancy to create a "milkshake pudding" in the the oil filler tube. This is mixture of oil and water, mostly from humidity.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 5 (permalink) Old 03-26-2010, 12:52 PM
Date registered: Nov 2007
Vehicle: 2006 R350 1999 ML430 2003 Audi Allroad
2nd This. You can view/ download an owner's manual here.Mercedes-Benz - Home of C, E, S, CLK, CLS, CL, SLK, SL, SLR, R, GLK, M, GL, G Class
2006 R350
1999 M430
cadillacbart is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
    2006 C230 Engine Oil Capacity spoons W203 C-Class 4 08-18-2009 10:52 AM
    C36 AMG 1995 engine oil capacity??? jayrash W202 C36 AMG, C43 AMG 3 06-02-2009 02:35 PM
    2006 C230 Engine Oil Capacity spoons W203 C-Class 5 05-17-2007 01:45 AM
    Oil Capacity CplRowland W126 S,SE,SEC,SEL,SD,SDL Class 8 08-23-2006 01:27 AM
    Say you have a 2.3 engine or a 3.2 engine. Is that called engine size ? engine capacity ? Vince R170 SLK-Class 4 11-01-2001 08:14 PM
