Check Engine LIght on 2006 R350 - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 12-22-2009, 01:33 PM Thread Starter
Date registered: Feb 2009
My check engine light recently went on but there was no apparent issue with the vehicle.
I called the dealer and was told that it goes on sometimes if the gas cap is not sealed correctly and will correct itself once thats done.
So i double checked the gas cap, tightened it (wasn't really loose), and low and behold, three starts later, the check engine light is gone.
does anything think I have anything to worry about?
PensBenzFan is offline
post #2 of 14 (permalink) Old 12-23-2009, 11:18 AM
mitaka's Avatar
No problem at all. If it comes back get the code. You should be OK.
2012 E550 P1, Driver Assist Pkg, Sport Pkg 18' OEM AMG Wheels, Distronic
Other/ Previous cars:
14 Volvo XC60 T6 AWD
09 R350
07 R320 CDI
Audi A8 4.2 Quattro
mitaka is offline
post #3 of 14 (permalink) Old 12-25-2009, 08:47 AM
Date registered: Nov 2008
Vehicle: 2006 R3504M, 2007 E3504M
You should get the code. There is a known issue with the 272/273 engine with the camshaft sprocket. I heard that about 10% of the engines have the failure. If you're still under warranty, you want to get this fixed as it is very expensive. The only symptom is the check engine light, you won't feel or hear anything. The codes triggered by this failure are numerous: 1200, 1208, 0059, 0060, 0063, 0064, 0271, 0272, 0275. This is fully described in the service bulletin S-B-03.30/08j.
2006 R350 4MATIC
2007 E350 4MATIC
lippens is offline
post #4 of 14 (permalink) Old 12-25-2009, 12:36 PM Thread Starter
is there any way for me to get the code without going to the dealership?
post #5 of 14 (permalink) Old 12-25-2009, 03:11 PM
Of course. Check engine is a standard diagnostic for all cars in north america since 1996. Just buy a ODB II scanner at any auto car parts (~100$), plug it under the dash, and read the codes.
2006 R350 4MATIC
2007 E350 4MATIC
lippens is offline
post #6 of 14 (permalink) Old 12-28-2009, 04:00 PM Thread Starter
Of course, the check engine light went on again. Kept my appt with the dealership. First use of my extended warranty if there is a problem...
post #7 of 14 (permalink) Old 12-29-2009, 06:34 AM
Did you read the code? If so, what is it?
2006 R350 4MATIC
2007 E350 4MATIC
lippens is offline
post #8 of 14 (permalink) Old 01-01-2010, 08:56 PM
Date registered: Nov 2006
I have this same issue with the check engine light for a year now. I brought the vehicle(2006) to the dealership many times and they say its the gas cap. The dealerships performed a couple of gas tank pressure test but that wasn't problem. The dealerships (in NYC) stated that the problem was from a short to an internal module. However the problem persist. I will bring the vehicle to the dealership armed with the service bulletin in hand....I will keep everyone updated.
smxnyc is offline
post #9 of 14 (permalink) Old 01-02-2010, 06:26 AM
I suggest you read the code first and then browse the DTBs in Startek info. It's worth spending 18$ for a day. There are many bulletins describing various known issues and related ODB codes. However, I'd expect all dealers to be very familiar with all DTBs.
2006 R350 4MATIC
2007 E350 4MATIC
lippens is offline
post #10 of 14 (permalink) Old 01-06-2010, 11:46 PM
Date registered: Dec 2006
Vehicle: 2008 CL63; 2007 R63; 2001 S55 (sold ... and I miss it); 1996 Porsche 993 C4S; 2014.5 Range Rover LWB
had the same light. Was on for two days then went off. Took the vehicle in ... exhaust mainfold leak.
Will have the paperwork tomorrow when I go to pick it up. All warranty work.
2001S55 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
    2006 ML-350 check engine light on! zzsprm0 W164 M-Class 25 01-16-2014 06:55 PM
    2006 R350 Engine Oxidation WillBeeGee General Mercedes-Benz 0 02-08-2009 07:44 PM
    2006 C280 4matic Check engine light merce-deez W203 C-Class 4 03-21-2008 12:11 PM
    1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 10:19 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 03:37 PM
