» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 11-12-2009, 09:33 AM   #1 (permalink)
Date registered: Aug 2009
Vehicle: '06 R5
Knocking Noise in Rear
i took the R in for service for a 2nd time for a knocking noise in the rear suspension when going up a driveway and the dealership said it's a normal for R. they said they tested about 3 Rs and all of them have duplicated the knocking noise.
they already changed some rear suspension components under warranty the first time i complained about this, but the knocking is still there. the feeling is like something back there is popping out of place and it only occurs going up a driveway in an angle, not straight up.
does your R make this noise? i don't think it's normal at all.
RedSER13 is offline   Reply With Quote
Old 11-12-2009, 01:10 PM   #2 (permalink)
Wyatt_Earp's Avatar
Date registered: Mar 2009
This is not normal if it is the same thing I had.
The rear left shock likely has a blown resevior and the auto air suspension compressor relay doesn't or can't function, resulting in a dead spot or knocking noise when you hit a bump.
There is a technical service bulletin for it - see the sticky in this forum and look for your car.
Wyatt Earp
2008 R320 CDI - Diesel Luxury
2003 VW Golf TDI GLS 5spd, AFE Stage 1, Timing bumped, Sitting on Yoko 225/17 and Eagle Rims with lots of go for cheap
2002 Dodge 2500 Cummins Diesel LWB, 4x4, SLT, Quad Cab, 6spd, 2" LVL kit, DSS, Stage 5 sticks, AFE stage 2, ATS Manifolds, Smarty Box, Comp Box, Trailer Brakes, Custom lights and switches, FP, Boost and Pyro gauges, Ring MIA, Sitting on 33" Toyo MT's
Save the Planet, Drive an Oil Burner
Wyatt_Earp is offline   Reply With Quote
Old 11-12-2009, 09:58 PM   #3 (permalink)
Vehicle: '06 R5
wow, there's a lot of info there, i hope i can find it.
once i find it, do i tell the dealership the tsb number?
thanks.
Old 11-13-2009, 04:13 AM   #4 (permalink)
BobbyHowie's Avatar
Date registered: Feb 2005
Vehicle: 2005 SL500, 2007 R350 Sport LWB
Normal?!! Nup. Good luck.
BobbyHowie is offline   Reply With Quote
Old 11-13-2009, 05:54 AM   #5 (permalink)
Eraser-X's Avatar
Date registered: Jan 2005
Vehicle: 2006 E55
Send a message via ICQ to Eraser-X Send a message via AIM to Eraser-X Send a message via Yahoo to Eraser-X
Does your car have ADS? We had a similar issue on our 06 R350 with failed ADS struts. How many miles on your R?
Eraser-X
07 R500 Silver/Charcoal, P02
06 E55 Platinum Blue, Charcoal/Dark Blue 051, 319, 526
96 Turbo Miata running 13 psi (for the track)
53 356 Cab
Eraser-X is offline   Reply With Quote
Old 11-13-2009, 06:45 AM   #6 (permalink)
Wyatt_Earp's Avatar
thanks.
If they are a little "thick" you can quote all the TSB numbers and say look, clearly it is a problem but I'm not certain which number applies to my build date.
Old 11-13-2009, 07:55 AM   #7 (permalink)
Vehicle: '06 R5
ok. i'll write to my service advisor about the TSB.
ADS? i'm not sure. we only have the comfort/sport selection. the R has about 39k miles.
Old 11-19-2009, 11:27 PM   #8 (permalink)
Date registered: Jan 2009
I have the similar noise. Dealer say it's normal. They also tested other R and say it's the same. My is 06 R350.
melvinh is offline   Reply With Quote
2003 C320 Rear Knocking Noise biddled W203 C-Class 3 01-18-2010 12:59 PM
Knocking noise at the rear SilferME R170 SLK Class 7 10-19-2009 12:01 PM
Mysterious knocking noise in rear - ideas please Littlesiam R/C107 SL/SLC Class 5 06-24-2008 03:05 AM
Rear susoension knocking noise Stdalo W220 S-Class 1 04-27-2006 12:56 PM
rear knocking noise -dealer no help Heather R170 SLK Class 14 06-26-2001 03:52 AM
