» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Old 10-31-2009, 07:19 PM   #1 (permalink)
HeadhunterGL's Avatar
Date registered: Apr 2009
Vehicle: 2006 R350
Daylight savings time - will clock reset itself?
I have a 2006 RClass with NAV - time zone set to EST.
Thanks!
HeadhunterGL is offline   Reply With Quote
Old 11-01-2009, 04:42 AM   #2 (permalink)
Vehicle: 2006 R350
Just thought I would answer my own question in case it would help others. I noticed this morning that it did not reset itself. After a few minutes of messing around with the NAV, I found out that you need to go to services, time, and then Eastern Time. When you select Eastern Time, it will ask day light savings or standard time. You have to select standard time for the clock to fall back 1 hour. After selecting that it showed on the NAV, but it did not sync the analog clock. I had to turn the ignition to the on position for the analog clock to sync and I watched it move backwards. Hope this is helpful – this was the first time I had to set the clock back in my RClass.
Daylight savings time s430owna W215 CL Class 3 11-10-2007 05:03 AM
daylight savings time 2004 SL 500 R230 SL Class 7 04-02-2007 07:50 AM
Daylight Savings Time - Forum Clock asianml BenzWorld Help 15 03-15-2007 08:12 AM
Time reset for daylight savings with NAV paulcars GL Class 7 03-12-2007 09:57 PM
Dumb Question - How do I reset the Clock for Daylight Savings Time? AndyFracica W164 M-Class 6 04-07-2006 04:21 AM
